Warning message
IGMP Snooping configuration for Multicasting on Cisco Catalyst 3020
Nov 25th, 2011
Hi Guru,
Our switch model is "Cisco Catalyst Blade Switch 3020 for HP"
We are building HA (High Availability) Databases infrastructure.
Currently, there are two nodes(hosts- servers) and two above switch for HA.
Oracle said we need to turn off the IGMP Snooping in order to use the multicasting for their interconnect communication.
So my question is:
Q1> Is there any way to use Multicasting without turning off IGMP Snooping on Switch side?
Q2> If 'yes', how can we configure the switch for Multicasting ?
Oracle uses 230.0.1.0 & 224.0.0.251 IPs with 42000 range port for Multicasting communication.
Please shed some light on it
Leo Laohoo Fri, 11/25/2011 - 19:03
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
May I request if you avoid making multiple posts of the same issue?  This will only confuse people (including you).
