Warning message
Brand new RV 120W PPPOE fail - pppoeMgmtDBUpdateHandler: error in executing database update handler
Nov 26th, 2011
I'm trying to get PPPOE working, firmware is latest one, default settings, got this in the log:
Jan 1 00:03:30 2000(UTC) [rv120w][System][PLATFORM] pppoeMgmtTblHandler: pppoe enable failed
Sat Jan 1 00:03:30 2000(UTC) [rv120w][System][PLATFORM] pppoeMgmtDBUpdateHandler: error in executing database update handler
Sat Jan 1 00:03:31 2000(UTC) [rv120w][System][NIMF] nimfAdvOptSetWrap: NIMF table is NimfTrigger
Sat Jan 1 00:04:06 2000(UTC) [rv120w][System][PLATFORM] pppoeMgmtTblHandler: pppoe enable failed
Sat Jan 1 00:04:06 2000(UTC) [rv120w][System][PLATFORM] pppoeMgmtDBUpdateHandler: error in executing database update handler
Sat Jan 1 00:04:06 2000(UTC) [rv120w][System][NIMF] nimfAdvOptSetWrap: NIMF table is NimfTrigger
Sat Jan 1 00:04:48 2000(UTC) [rv120w][System][PLATFORM] pppoeMgmtTblHandler: pppoe enable failed
Sat Jan 1 00:04:48 2000(UTC) [rv120w][System][PLATFORM] pppoeMgmtDBUpdateHandler: error in executing database update handler
Sat Jan 1 00:04:48 2000(UTC) [rv120w][System][NIMF] nimfAdvOptSetWrap: NIMF table is NimfTrigger
Sat Jan 1 00:05:25 2000(UTC) [rv120w][System][PLATFORM] pppoeMgmtTblHandler: pppoe enable failed
Sat Jan 1 00:05:25 2000(UTC) [rv120w][System][PLATFORM] pppoeMgmtDBUpdateHandler: error in executing database update handler
Sat Jan 1 00:05:25 2000(UTC) [rv120w][System][NIMF] nimfAdvOptSetWrap: NIMF table is NimfTrigger
Sat Jan 1 00:05:39 2000(UTC) [rv120w][System][PLATFORM] mirrorEnable: mirrorProgram enabled successfully
Sat Jan 1 00:05:55 2000(UTC) [rv120w][System][PLATFORM] mirrorEnable: mirrorProgram enabled successfully
Sat Jan 1 00:06:00 2000(UTC) [rv120w][System][PLATFORM] pppoeMgmtTblHandler: pppoe enable failed
Sat Jan 1 00:06:00 2000(UTC) [rv120w][System][PLATFORM] pppoeMgmtDBUpdateHandler: error in executing database update handler
Sat Jan 1 00:06:00 2000(UTC) [rv120w][System][NIMF] nimfAdvOptSetWrap: NIMF table is NimfTrigger
Sat Jan 1 00:06:36 2000(UTC) [rv120w][System][PLATFORM] pppoeMgmtTblHandler: pppoe enable failed
Sat Jan 1 00:06:36 2000(UTC) [rv120w][System][PLATFORM] pppoeMgmtDBUpdateHandler: error in executing database update handler
Sat Jan 1 00:06:36 2000(UTC) [rv120w][System][NIMF] nimfAdvOptSetWrap: NIMF table is NimfTrigger
Sat Jan 1 00:07:00 2000(UTC) [rv120w][System][PLATFORM] platformHandleDBUpdate:mirrorConfig op=23 row=1
Sat Jan 1 00:07:00 2000(UTC) [rv120w][System][PLATFORM] mirrorDBUpdateHandler: update received: Table: mirrorConfig opCode: 23 rowId: 1
Sat Jan 1 00:07:00 2000(UTC) [rv120w][System][PLATFORM] mirrorDisable: Mirror Program disabled successfully
Sat Jan 1 00:07:00 2000(UTC) [rv120w][System][PLATFORM] mirrorEnable: mirrorProgram enabled successfully
Sat Jan 1 00:07:13 2000(UTC) [rv120w][System][PLATFORM] pppoeMgmtTblHandler: pppoe enable failed
Sat Jan 1 00:07:13 2000(UTC) [rv120w][System][PLATFORM] pppoeMgmtDBUpdateHandler: error in executing database update handler
Sat Jan 1 00:07:14 2000(UTC) [rv120w][System][FIREWALL] restartStatus = 1 for LogicalIfName = WAN1
Sat Jan 1 00:07:14 2000(UTC) [rv120w][System][PLATFORM] platformHandleDBUpdate:ipAddressTable op=23 row=2
Sat Jan 1 00:07:14 2000(UTC) [rv120w][System][PLATFORM] pptpdMgmtDBUpdateHandler:DBUpdate event: Table: ipAddressTable opCode:23 rowId:2
Sat Jan 1 00:07:14 2000(UTC) [rv120w][System][PLATFORM] options.pptpd file found
Sat Jan 1 00:07:15 2000(UTC) [rv120w][System][PLATFORM] upnpMgmtDBUpdateHandler:DBUpdate event: Table: ipAddressTable opCode:23 rowId:2
Sat Jan 1 00:01:55 2000(UTC) [rv120w][System][PLATFORM] [BONJOUR_DEBUG]: Getting the results of Sql Query: SELECT value FROM environment WHERE name='BONJOUR_DEFAULT_SERVICE_NAME'
Sat Jan 1 00:01:55 2000(UTC) [rv120w][System][PLATFORM] [BONJOUR_DEBUG]: Performing SqlQry : UPDATE bonjourDefaultServices SET textRecord = 'model=RV120W;deviceType=Router;deviceDescr=Wireless-N-VPN-Router;slaves=0;fmVersion=1.0.2.6;PIDVID=RV120W-E V01;MACAddress=E8B748266706;serialNo=SER152805MI;
Sat Jan 1 00:01:55 2000(UTC) [rv120w][System][PLATFORM] [BONJOUR_DEBUG]: Performing SqlQry : UPDATE bonjourDefaultServices SET serviceID = 'router266706'
PPPOE user name has @ symbol. PPPoe connection from WinXP working well, so username and passord are correct.
mpyhala Mon, 11/28/2011 - 12:10
  • Gold, 750 points or more
Hi Sergey,
Thank you for posting. If you have not done so already, set the router to factory defaults and set the time correctly. Then create the PPPoE profile and apply it to the WAN port again. After you have established the connection continue with the rest of the configuration.
