Can HWIC-1CE1T1-PRI support voice applications
Nov 27th, 2011
The product sheet and another helpful forum post clearly states that the HWIC-1CE1T1-PRI does NOT support voice applications on the PRI, only data applications. However, running 15.2(1)T when we configure a PRI group, it seems to imply that it can support a voice application with a command option to the PRI-group.
dal-rtr02(config-controller)#pri-group timeslots 1-24
%PRI-group is created for data application only.
%For voice application, please remove this pri-group, then configure pri-group again with voice-dsp option.
What gives? I cannot find this command documented anywhere. What does the "voice-dsp" option for the "pri-group timeslots" do?
Should we assume this card can STILL not be used for SIP/TDM Voice gateway services?
Thanks for any tips/confirmation you can provide.
Kris
Overall Rating: 2 (1 ratings)
Karthik Sivaram Wed, 11/30/2011 - 08:54
hi Kris,
Yes  what you read in the product data  sheet is right . ( why do you doubt it ?   )
HWIC-1CE1T1-PRI are  for data-isdn and not for voice.
Hope that helps!
Karthik
Kris Thompson Fri, 12/02/2011 - 13:48
Understood, but what is this "voice-dsp" option for on the end of the "pri-group timeslots" command?
This seems undocumented.
The router output is confusing and implies you could use the "voice-dsp" option to enable voice application. What is this all about? Best ignored I guess. The customer is now buying the correct hardware.
Related Content
