IP Phone does not play busy tone on PBX phone busy
Nov 27th, 2011
  • Bronze, 100 points or more
I have a H.323 gateway connected to a legacy PBX device via ISDN E1. Calls are working ok but the user epxerience is when the second call goes through to the same PBX extension is not a busy tone but the annoucment stating that the call cannot be complted as dialled and to check the number. The Q931debug does report User Busy so just a bit unsure why CUCM does not pass busy tone to the phone.
Looking at the cause code from the PBX Side I see 0x8191, user busy (CUCM plays annoucement)
Looking at the cause code from the PSTN Side i see 0x8491, user busy (CUCM plays busy tone)
http://www.cisco.com/en/US/partner/tech/tk801/tk379/technologies_tech_note09186a008012e95f.shtml
81 = the private network near the local user (possibly a local private           branch exchange [PBX])
84 = the public network near the remote user (remote telco           switch)
only non default item under the pots dial-peer is:
tone ringback-alert-noPI
acampbell Mon, 11/28/2011 - 02:46
  • Green, 3000 points or more
Can you try adding the following to the global config
voice rtp send-recv
voice call convert-discpi-to-prog
Alex
