Warning message
Video Streaming From Inside to outside via Static Nat
Nov 28th, 2011
Hi Guys,
I've a security camera server located "inside" the network, i did a static nat for it, to be accessible from outside (internet) and be able to view the video streaming.
static (inside, outside) 192.168.1.3  1.2.3.4
access-list out_acl permit ip any host 1.2.3.4
i can access the server from outside using 1.2.3.4 ip address (via the web browser) & log-in to it, but when i reach to the web streaming page, i just see a white page.
From inside (using 192.168.1.3, i can access it and see the video streaming normally)
i tried to configure multicasting but no luck (by specifing PIM rp-address), i also played with the inspection but same problem.
what colud be the issue?  any idea how to solve this in order to be able to view the video streaming from outside?
Thanks & Regards,
Rami
Lee Valentin Mon, 11/28/2011 - 02:59
Try disabling fixup protocol rtsp
if that doesn't work, call the camera Manufacturer and ask them which ports need to be opened.
there could be more protocols that are being inspected that the camera requires for functionality.
good luck.
