Warning message
DTMF FROM PSTN TO A SIP TRUNK
Nov 28th, 2011
I dear im facing a big issue here.
I have a CCME 7.1 running IOS c2900-universalk9-mz.SPA.150-1.M6.bin. This CCME is connected to PSTN using BRI interfaces for outbound and inbound public phone calls. The company also needs to make some calls to a SIP server ( a kind of IVR) over a sip trunk that is beyond the wan VSAT link.
When I make the call using some SCCP and SIP phones registered on the CCME, I can send DTMF to the IVR system but when the call comes from PSTN via BRI the call gets connected but i cant send DTMF to the IVR system.
On the first attempt neither phones (PSTN or internal) were able to call this IVR but  I had to configure software MTP and the internal phones could call the IVR system over WAN VSAT link.
This is the configuration of the CCME. Check also the attachment
sh running-config
Building configuration...
network-clock-participate wic 0
network-clock-participate wic 1
isdn switch-type basic-net3
trunk group AAA_MOBILE_BRI
hunt-scheme longest-idle
voice-card 0
dspfarm
dsp services dspfarm
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
h323
  no telephony-service ccm-compatible
sip
  registrar server
voice class codec 2
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice register global
mode cme
source-address 172.16.X.250 port 5060
timeouts interdigit 4
max-dn 40
max-pool 20
timezone 29
time-format 24
date-format D/M/Y
tftp-path flash:
create profile sync 000342051580142A
voice register dn  6
number 255
name 255
label 255
voice register pool  6
id mac 0000.0000.0005
number 1 dn 6
dtmf-relay rtp-nte
username 255 password 255
codec g711ulaw
voice hunt-group 1 sequential
final 3000
list 254,253,252,251,250
pilot 3000
interface GigabitEthernet0/0
description LINK-TO-SW-AAA-SEDE-01
ip address 172.16.X.250 255.255.255.0
duplex full
speed 1000
h323-gateway voip interface
h323-gateway voip bind srcaddr 172.16.X.250
interface BRI0/0/0
no ip address
isdn point-to-point-setup
isdn incoming-voice voice
isdn static-tei 0
trunk-group AAA_MOBILE_BRI
interface BRI0/0/1
no ip address
isdn static-tei 0
interface BRI0/1/0
no ip address
isdn static-tei 0
interface BRI0/1/1
no ip address
isdn static-tei 0
ip route 0.0.0.0 0.0.0.0 172.16.X.254
voice-port 0/0/0
compand-type a-law
cptone PT
voice-port 0/0/1
compand-type a-law
cptone PT
voice-port 0/1/0
compand-type a-law
cptone PT
voice-port 0/1/1
compand-type a-law
cptone PT
sccp local GigabitEthernet0/0
sccp ccm 172.16.X.250 identifier 1 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register MTPAAA
keepalive retries 1
keepalive timeout 10
switchover method immediate
switchback method immediate
dspfarm profile 1 mtp
description MTPAAA
codec g711ulaw
maximum sessions software 100
associate application SCCP
dial-peer voice 1 pots
incoming called-number .
direct-inward-dial
dial-peer voice 300 voip
description ----- SIPTrunk to OneContact -----
destination-pattern 6...
session protocol sipv2
session target ipv4:A.B.C.19
voice-class codec 2
dtmf-relay rtp-nte sip-notify
no vad
telephony-service
sdspfarm units 1
sdspfarm tag 1 MTPAAA
max-ephones 25
max-dn 50
ip source-address 172.16.X.250 port 2000
system message AAAA
cnf-file location flash:
cnf-file perphone
user-locale PT
network-locale PT
load 7937 apps37sccp.1-2-1-0.bin
time-zone 29
time-format 24
date-format dd-mm-yy
max-conferences 8 gain -6
call-forward pattern 2..
moh music-on-hold.au
transfer-system full-consult
transfer-pattern 2..
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-template  1
softkeys hold  Resume Newcall
softkeys idle  Redial Newcall Dnd Cfwdall Pickup
softkeys alerting  Endcall Callback
softkeys connected  Endcall Hold Trnsfer Park Confrn
softkeys ringing  Answer Dnd
ephone-dn  1  dual-line
number 200
description YYYY
name YYYY
corlist incoming Class-30
ephone-dn  2  dual-line
number 201
pickup-group 298
description KKKK
name KKKK
corlist incoming Class-40
ephone  1
mac-address 6C50.4DDA.5528
ephone-template 1
type 7962
button  1:1 2w2 3w3 4w4
button  5w5
ephone  2
mac-address E8BA.70FA.7387
ephone-template 1
type 7911
button  1:2
Carlo Poggiarelli Mon, 11/28/2011 - 02:15
  • Green, 3000 points or more
Can you please send a show voice call status when call from PSTN is connected to IVR?
Please send also a show viop rtp connections.
Let me know
Carlo
zacariasnhancune007 Mon, 11/28/2011 - 02:51
I dear,
sh voice call status
CallID CID ccVdb Port Slot/DSP:Ch Called # Codec MLPP Dial-peers
0x47F7 2A1F 0x29BDEE34 0/1/1.1 0/1:2 6200 g711alaw 1/300
1 active call found
sh voip rtp connections
VoIP RTP active connections :
No. CallId dstCallId LocalRTP RmtRTP LocalIP RemoteIP
1 18422 -1 16384 0 172.16.X.250 0.0.0.0
2 18424 18423 16434 18894 172.16.X.250 A.B.C.11
Found 2 active RTP connections
Com as melhores saudações/With Best regards
Zacarias Nhancune-Netwoking Engineer-CCNP,CCNA,CCNA Voice -11183622
Carlo Poggiarelli Mon, 11/28/2011 - 08:32
Hi.
Because you configured MTP session with G711ulaw as codec, you should try to chanche compand-type to ulaw to your Voice ports.
Hope this helps
Carlo
zacariasnhancune007 Mon, 11/28/2011 - 08:52
Dear, I have tried but didn’t work too.
The sound get distorted.
Carlo Poggiarelli Mon, 11/28/2011 - 11:11
Hi.
In this case configure back to compand type a-law your voice port an try to force codec g711ulaw to your dialpeer 300.
Let me know.
Carlo
ADAM CRISP Mon, 11/28/2011 - 13:24
  • Silver, 250 points or more
Hello.
Please capture the output of "debug ccsip messages" while you place a call to your IVR. This will allow us to see any out of band DTMF method offered by the external system.
Adam
shrvaran Mon, 11/28/2011 - 23:03
  • Cisco Employee,
Hi Zacarias,
Please add below commands under "dspfarm profile 1 mtp"
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
Issue command
no sccp
then
sccp
Then place a call from PSTN and see if it works.
Also please check if MTP is invoked when call is placed from PSTN.
zacariasnhancune007 Tue, 11/29/2011 - 00:00
Hi dear,
It accepts only one codec at a time
zacariasnhancune007 Fri, 12/23/2011 - 01:58
Hi dear,
I have another issue. Please help:
Im running a CUCM Business Edition 6.1 (2) and after a hard reset it say:
/common contains a file system with errors, check forced
/common Inodes that were part of a corrupted orphan link list found.
/common: UNEXPECTED INCONSISTENCY; RUN fsck MANUALLY (i.e. without -a or -p options)
/grub: clean, 26/66520 files, 16820/265072 blocks
/partB: clean, 11/3515680 files, 118535/7018396 blocks
      • An error occured during the file system check.
      • Dropping you to a shell; the system will reboot
      • when you leave the shell.
Give root password for maintenance
(or type Control-D to continue):
ADAM CRISP Mon, 11/28/2011 - 23:20
Hello.
Thank you for the SIP trace.
Your trace shows  SIP to SIP call, I imagine from a SIP telephone to your IVR. The 200 OK from the IVR clearly shows it expects to receive RTP-NTP with payload type 101. I suspect this is working OK.
Please can you now gather a SIP trace originating the call from the PSTN for comparison ?
thanks
zacariasnhancune007 Mon, 11/28/2011 - 23:58
Hello Adam,
the pstn number im using to call inbound is 820887712. I mean, from 820887712 im calling 95100 which is a gsm/pstn number allocated to the company. This 9500 is a SIM card that is inserted in a ISDN COM.SAT BRI Modem and this one too is connected to my CCME( VIC2-2BRI-NT/TE card) using a BRI interface. When I call this 95100 the modem is configured to translate it to 6200 which the IVR number.
So the trace a sent you is from the outside. There is also some calls coming into the system but forget about does calls.
Carlo Poggiarelli Tue, 11/29/2011 - 00:27
Hi.
Did you try to set g711ulaw codec to your DP 300?
Can you also attach a trace of a call from an IP phone?
Carlo
zacariasnhancune007 Fri, 12/23/2011 - 01:57
Hi dear,
ADAM CRISP Tue, 11/29/2011 - 00:23
Since you're encoding from ISDN to SIP, the DSP modules will already be detecting DTMF if present in the Audio stream
The 200 OK signals RTPNTE payload type 101 - so next job is to see whether you're sending this:
debug voip rtp packet - will create a lot of ourput so don't do this over the console; suggest logging to memory buffer and then after your test - show log
You're looking for the RTP payload changing to 101 for DTMF and then the RTP data should show the DTMF digit
thanks
ADAM CRISP Tue, 11/29/2011 - 00:54
Hello.
I need to travel now.
If you trace shows DTMF being sent - then look for the DTMF volume - duration and check to see whether this is compatible with your IVR
If your trace shows NO DTMF, then this is not being detected by the DSP's which means that DTMF is not present in-band from the BRI port. You could try upping the input gain - but I would tink looking at the GSM gw would be the next place to check.
Again - you don't need any MTP for this. DSP's are already involved.
Good luck
Adam
zacariasnhancune007 Tue, 11/29/2011 - 05:04
Dear Adam and Carlo,
I have found the problem, the provider is not sending the DTMFs, I have tried another provider and everything was ok.
So now Im trying to see it with them.
Many thanks for your help.
Hi dear,
Related Content
