Outgoing Call Routing
Hi team,
I have a UC560 with 12 FXO lines. How can I route outgoing calls based on the source.
     eg:
          - extension 100 to 105 should always go via FXO port 1
          - extension 106 to 110 should always go via FXO port 2
Nuwan
acampbell
You will need to configure Class Of Restriction
COR
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeblock.html#wp1022877
Hth
Alex
Regards, Alex. Please rate useful posts.
Hi Alex,
Thanks for your response. Can I do this using CCA 3.1?
Nuwan
I have had a search for configuring CoR via CCA but I can not find very much
I dont use CCA in my day job so if it was me I would need
to use cli.
I am including another link which gives a good explanation of CoR.
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a008019d649.shtml
You could also try asking your CCA question under the "small business forum" where I am sure
you will obtain further help.
https://supportforums.cisco.com/community/netpro/small-business
Alex
