Warning message
I need LLD template.
Answered Question
Nov 28th, 2011
hi,
We are going to deploy network infrastructure by Cisco Switches & Routers. So I need LLD template.
thanks,
Qamrul
Correct Answer by Phillip Hichens about 5 years 8 months ago
Hi Qamrul
LLDs are part of your IP, so most will not share. Cisco has some good templates for partners, especially for VoIP deployments.
If you are doing your own include some of the following topics with specific relevance to your design
- Technology
     i.e. OSPF works like this and that is why it was chosen for the core IGP. The following enhancements will be deployed and a typical core router wil have the following ospf config applied
- Hardware used
- Network topology (Physical and Logical)
- Deployment/Implementation plan
Cheers
Overall Rating: 5 (1 ratings)
Correct Answer
Phillip Hichens Wed, 11/30/2011 - 15:34
Hi Qamrul
- Technology
- Hardware used
Cheers
