Users unable to access external email servers ASA even with inspect esmtp removed
powermann
Hi All. I have a issue that i am at a loss as how to slove it. I have an ASA 5505 as my firewall. I have users from other companies who visit from time to time and are unable to use their outlook email to send messages. They can however receive messages without a problem. I also have a situation where users who use windows live to access gmail are unable to send messages.
I have narrowed it down to the fact that these uses are using  ssl/tls to send the mails. I did some reseach and found out about the inspect esmtp setting in the ASA.  I have disabled it and i still have to problem. I have also removed all outbound deny statements and still no luck.
Of note is that i can send emails without atachments. They take a long time to go out ( from minutes to hours) but eventually they do. Emails with attachments of even 10k do not go at all.
I was running image 8.2.3 and i downgraded to 8.0.5...still did not work...i upgraded to 8.4.3...still did not work. I am now back at 8.2.3. I would really appreciate some insite into solving this problem.
My Firewall config is atached. I am at my witts end as to what elese to try. The company has not renewed support for the device so i am on my own here! I would really appreciate you help.
Marlon
mirober2
Hi Marlon,
Do you see any syslogs in ASDM for this traffic when a connection fails? That will give us more information about why this is failing.
-Mike
Thanks for the response Mirober2
I found a work around for the problem. I  looked at the issue from the end point and found that windows 7 handles tcp windowing diffrently than previous OS's. I still think there is an issue somewhere but i am not sure where esle to look so i will work with this for now.
See note below. Thanks for your help guys.
Disable the auto tuning
Check the state or current setting of TCP Auto-Tuning
1.          Open elevated command prompt with administrator’s privileges.
2.          Type the following command and press Enter:
netsh interface tcp show global
The system will display the following text on screen, where you can check on the Auto-Tuning setting:
Querying active state…
TCP Global Parameters
Receive-Side Scaling State : enabled
Chimney Offload State : enabled
Receive Window Auto-Tuning Level : normal
Add-On Congestion Control Provider : none
ECN Capability : disabled
RFC 1323 Timestamps : disabled
Disable TCP Auto-Tuning
netsh interface tcp set global autotuning=disabled
Enable TCP Auto-Tuning
netsh interface tcp set global autotuning=normal
http://www.mydigitallife.info/disable-tcp-auto-tuning-to-solve-slow-network-cannot-load-web-page-or-download-email-problems-in-vista/
