Automating the CCM configuration
ricardorojas123
There is a tool for automating the configuration of regions, device pools in the server, such as the bat.xls?
Chris Deren
You can use import/export features, basically build one manaully export it, adjust names/settings/etc and then import.
Also, with some programming you can use AXL API to build your own tools.
HTH,
Chris
Thanks, I will try whit the Import/Export.
