Warning message
Converting Octel Contributor mailbox app to Unity/Unity Connection ?
Nov 29th, 2011
I have one remaining voicemail application on an old Octel system that needs to be converted to Unity or Unity Connection.  The application is for customers to call into and listen to the status of pending jobs. The customer hears the message for each job, one after each other.  No sign in, passwords or key entry is needed by the customer. Typically there are 1 to 7 messages that the customer can listen to. Each job/message is added by an internal contributor mailbox via several different employees throughout the day.  It is not practical to re-record the previous messages when adding a new message.
Can a similar application be setup in Unity/Unity Connection?
Rob Huffman Wed, 11/30/2011 - 09:06
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi James,
Can you please tell us what type of mailbox(s) you are using for this on
the Octel (Type 1, Type 31, Type 5??) And also, if you could, please
describe the actual method of being able to record only a single portion
of the script for new jobs? Are they all single mailboxes linked together
behind the scenes so that a user (contributor) can send to a specific
portion/mailbox?
Cheers!
Rob
