Warning message
ASA 5505 Blocking FTP
Answered Question
Nov 29th, 2011
Hello, I am new to the site so hello to everyone. Unfortunately I am also relatively new to firewalls and could do with some help. I am working on an ASA5505 and am trying to open the ftp port. I have a server (192.168.10.202) on the local LAN which is attempting to download antivirus updates from the net via ftp.
I have attached the config and would greatly appreciate any help I can get. Thanks.
Saved
ASA Version 8.3(2)
hostname SITE
enable password XXXXXX
passwd XXXXXX
names
name 255.255.255.255 Gateway
interface Vlan1
nameif inside
security-level 100
ip address 192.168.10.2 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 202.5.170.134 255.255.255.252
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
boot system disk0:/asa832-k8.bin
ftp mode passive
clock timezone PGT 10
dns domain-lookup inside
dns domain-lookup outside
dns server-group DefaultDNS
name-server 202.5.191.130
name-server 202.5.191.160
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network 192.168.10.201
host 192.168.10.201
object service RDP
service tcp source eq 3389 destination eq 3389
object network NETWORK_OBJ_192.168.10.0_24
subnet 192.168.10.0 255.255.255.0
object network canberra
subnet 10.10.0.0 255.255.0.0
object network Gateway
host 202.5.170.133
object network goroka-rdp
host 192.168.10.201
object network Canberra_DMZ
subnet 192.168.2.0 255.255.255.0
object network melbourne
subnet 10.0.0.0 255.255.255.0
object-group protocol DM_INLINE_PROTOCOL_1
protocol-object ip
protocol-object icmp
protocol-object tcp
object-group protocol DM_INLINE_PROTOCOL_2
protocol-object ip
protocol-object tcp
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
object-group network DM_INLINE_NETWORK_1
network-object object Canberra_DMZ
network-object object canberra
network-object object melbourne
object-group service DM_INLINE_SERVICE_1
service-object object RDP
service-object tcp destination eq domain
service-object tcp destination eq www
service-object tcp destination eq smtp
service-object udp destination eq domain
service-object udp destination eq nameserver
service-object tcp destination eq citrix-ica
service-object tcp destination eq https
object-group service DM_INLINE_SERVICE_2
service-object tcp destination eq ftp
service-object tcp destination eq ftp-data
object-group service DM_INLINE_SERVICE_3
service-object udp destination eq ntp
object-group service DM_INLINE_SERVICE_4
access-list outside_1_cryptomap extended permit ip 192.168.10.0 255.255.255.0 object-group DM_INLINE_NETWORK_1
access-list inside_access_in extended permit object-group DM_INLINE_PROTOCOL_1 any any log inactive
access-list inside_access_in extended permit object-group DM_INLINE_SERVICE_1 object NETWORK_OBJ_192.168.10.0_24 any log inactive
access-list inside_access_in extended permit object-group DM_INLINE_SERVICE_3 host 192.168.10.207 any log
access-list inside_access_in extended permit object-group DM_INLINE_SERVICE_4 host 192.168.10.4 any log
access-list inside_access_in extended permit tcp object NETWORK_OBJ_192.168.10.0_24 host 119.225.105.52 eq https log
access-list inside_access_in extended permit udp object NETWORK_OBJ_192.168.10.0_24 any eq ntp log
access-list outside_access_in extended permit tcp any host 192.168.10.201 eq 3389
access-list outside_access_in extended permit object-group DM_INLINE_PROTOCOL_2 any any inactive
access-list outside_access_in extended permit object-group DM_INLINE_SERVICE_2 any object NETWORK_OBJ_192.168.10.0_24 log inactive
tcp-map WSOptions
  tcp-options range 24 31 allow
pager lines 24
logging enable
logging asdm notifications
flow-export destination inside 192.168.10.207 2055
flow-export template timeout-rate 1
flow-export delay flow-create 15
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-633.bin
no asdm history enable
arp timeout 14400
nat (inside,outside) source static NETWORK_OBJ_192.168.10.0_24 NETWORK_OBJ_192.168.10.0_24 destination static canberra canberra
nat (inside,outside) static interface service tcp 3389 3389
nat (inside,outside) after-auto source dynamic NETWORK_OBJ_192.168.10.0_24 interface
access-group inside_access_in in interface inside
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 Gateway 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication telnet console LOCAL
http server enable
http server idle-timeout 240
http 192.168.10.0 255.255.255.0 inside
http 119.225.35.38 255.255.255.255 outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 set peer 119.225.35.38
crypto map outside_map 1 set transform-set ESP-3DES-SHA
crypto map outside_map 1 set security-association lifetime seconds 3600
crypto map outside_map interface outside
crypto isakmp enable inside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet 192.168.10.0 255.255.255.0 inside
telnet timeout 240
ssh timeout 60
console timeout 0
dhcpd auto_config outside
threat-detection basic-threat
threat-detection statistics host
threat-detection statistics port
threat-detection statistics protocol
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ntp server 150.203.1.10 source outside
webvpn
username
tunnel-group 119.225.35.38 type ipsec-l2l
tunnel-group 119.225.35.38 ipsec-attributes
pre-shared-key *****
isakmp keepalive threshold 15 retry 5
class-map WSOptions-class
match any
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map WSOptions
class WSOptions-class
  set connection advanced-options WSOptions
policy-map global_policy
class class-default
  flow-export event-type all destination 192.168.10.207
service-policy global_policy global
prompt hostname context
hpm topN enable
Cryptochecksum:
: end
Correct Answer by Julio Carvajal about 5 years 8 months ago
Hello John,
It is a pleasure to help.
Please mark the question as answered for future users with similar issues.
Have a great night.
Julio
Overall Rating: 5 (1 ratings)
Julio Carvajal Tue, 11/29/2011 - 18:20
  • Purple, 4500 points or more
Hello John,
Can you add the following line on the ACL:
access-list inside_access_in line 1 permit tcp any any eq ftp
Then can you provide the following output for me:
Show run policy-map.
Julio
fb_webuser Wed, 11/30/2011 - 08:58
  • Silver, 250 points or more
Hello John,
Try this:
Add access list to allow inbound ftp traffic and ftp data traffic:
access-list ftp_access line 1 permit tcp any host 192.168.10.202 eq ftp
access-list ftp_access line 2 permit tcp any host 192.168.10.202 eq ftp-data
access-group ftp_access in interface outside
Create object groups to define hosts:
object network Translated_IP
host (Ip address to which you need to translate)
object network local_lan_server
Configure manual NAT:
nat (inside,outside) source static Translated_IP local_lan_server
Configure ftp inspect:
class inspection_default
inspect ftp
Hope this helps
Posted by WebUser Sooraj Prasad
john-little Wed, 11/30/2011 - 17:08
Thanks both of you guys for the responses. I actually used ASDM to add a network object and then added a rule and it appears to be working...my antivirus updates are as we speak downloading to my server.
Again really appreciate you guys helping out.
John
Correct Answer
Julio Carvajal Wed, 11/30/2011 - 17:22
Hello John,
Have a great night.
Julio
