Limited PSTN calls on CUCM 8.6
I am facing an issue with maximum simultaneous PSTN calls in our office. We are currently running CUCM 8.6 with VGW 2801 router; 8 FXO lines. All lines are working fine. At any given time, I am able to use only max 5 lines for PSTN calls (incoming and outgoing included). The 6th call onwards gives a busy tone. Attached is the VGW config.
Any advice is appreciated.
Binu
Gajanan Pande Wed, 11/30/2011 - 00:49
  • Cisco Employee,
About the 6th port/line onwards, will it always be the same port, blocking the call or randomly the 6th, 7th & 8th calls ( no matter which port it goes thru ) are dropped ?
Did you collect any debug outputs ?
D_Lebedev Wed, 11/30/2011 - 01:51
Please,provide screen from Gateway Config_MGCP from your CM.
Also please pay attention to your Route groups...
Chris Deren Wed, 11/30/2011 - 06:42
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Have you attempted to reset the port?
Can you tried changing the trunk-group order to move the port to be the last one used?
Is this an FXO or FXS/DID line, if FOX what happens when you call the number associated with this line?
Chris
