Warning message
Vpn Client no received packets
Dec 1st, 2011
Hello
I did the config for a vpn with a asa 5520 the vpn client connects correctly but i can`t ping for the client to my lan until one pc of my lan ping the ip of the vpn client, can you help me?
hectorsalgado Fri, 12/02/2011 - 08:52
the config is
ASA Version 8.3(1)
hostname ciscoasa
enable password 2WKw2mlc5qeH8nmnTIY encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
dns-guard
interface GigabitEthernet0/0
nameif outside
security-level 0
pppoe client vpdn group ppoe-ira
ip address pppoe setroute
interface GigabitEthernet0/1
nameif inside
security-level 100
ip address 172.16.1.8 255.255.255.240
interface GigabitEthernet0/2
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
management-only
boot system disk0:/asa831-k8.bin
ftp mode passive
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object-group network DM_INLINE_NETWORK_1
network-object host 172.16.1.7
network-object host 172.31.151.222
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
object-group service DM_INLINE_SERVICE_1
service-object ip
service-object icmp
service-object tcp-udp destination eq domain
access-list inside_access_in extended permit ip object-group DM_INLINE_NETWORK_1 any
access-list inside_access_in extended permit object-group DM_INLINE_SERVICE_1 object-group Internet any
access-list inside_access_in extended permit object-group TCPUDP any any eq domain
access-list inside_access_in extended deny ip any any
access-list vpn_split standard permit 192.168.0.0 255.255.0.0
access-list vpn_split standard permit 172.31.0.0 255.255.0.0
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu management 1500
ip local pool vpn-pool 192.168.55.150-192.168.55.200 mask 255.255.255.128
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-631.bin
no asdm history enable
arp timeout 14400
nat (inside,any) source static any any destination static NETWORK_OBJ_192.168.55.128_25 NETWORK_OBJ_192.168.55.128_25
object network Net_172.31.151.0
nat (any,outside) dynamic interface
object network Net_192.168.51.0
object network Net_192.168.52.0
object network Net_192.168.53.0
object network Net_192.168.54.0
object network Net_192.168.55.0
object network Net_192.168.56.0
access-group inside_access_in in interface inside
route inside 172.31.0.0 255.255.0.0 172.16.1.7 1
route inside 172.31.151.0 255.255.255.0 172.16.1.7 1
route inside 192.168.0.0 255.255.0.0 172.16.1.7 1
route inside 192.168.50.0 255.255.255.0 172.16.1.7 1
route inside 192.168.51.0 255.255.255.0 172.16.1.7 1
route inside 192.168.52.0 255.255.255.0 172.16.1.7 1
route inside 192.168.53.0 255.255.255.0 172.16.1.7 1
route inside 192.168.54.0 255.255.255.0 172.16.1.7 1
route inside 192.168.55.0 255.255.255.128 172.16.1.7 1
route inside 192.168.56.0 255.255.255.0 172.16.1.7 1
route inside 192.168.100.0 255.255.255.0 172.16.1.7 1
route inside 192.168.200.0 255.255.255.0 172.16.1.7 1
route inside 192.168.202.0 255.255.255.0 172.16.1.7 1
route inside 192.168.250.0 255.255.255.0 172.16.1.7 1
route inside 192.168.254.0 255.255.255.0 172.16.1.7 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 management
http 0.0.0.0 0.0.0.0 outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65000 set pfs group5
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65000 set transform-set ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5 ESP-AES-128-SHA
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65000 set reverse-route
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption aes
hash sha
group 5
lifetime 86400
crypto isakmp policy 30
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 50
encryption aes
hash md5
group 5
lifetime 86400
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 outside
ssh timeout 5
console timeout 0
vpdn group ppoe-ira ppp authentication pap
vpdn username t4626266019 password ***** store-local
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
group-policy vpn-demo internal
group-policy vpn-demo attributes
split-tunnel-policy tunnelspecified
split-tunnel-network-list value vpn_split
username prueba5 password 5SsjHsNPiy24cMYU encrypted privilege 0
username prueba5 attributes
vpn-group-policy vpn-demo
tunnel-group vpn-demo type remote-access
tunnel-group vpn-demo general-attributes
address-pool vpn-pool
default-group-policy vpn-demo
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect dns
service-policy global_policy global
prompt hostname context
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email [email protected]
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:2df4260f34a46f20d7e51612845bac4e
: end
