vlans in different routers
Dec 1st, 2011
Hello, i have a big doubt
i have this scenary
site 1     ....................................................................Site2
pcvlan10---------switch-----router---------  ( WAN/CLOUD )------------------router----------swich------------pcvlan10
pcvlan11        pcvlan11
172.20.30.1        172.20.30.1
172.20.40.1        172.20.40.1
could be posssible  conect Vlans in this way????
Marwan ALshawi Thu, 12/01/2011 - 12:04
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
If the switch is L3 switch then you can enable ip routing and add static route or a routing protocol to advertise the different Vlans
Joseph W. Doherty Thu, 12/01/2011 - 12:35
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of    this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising    out of the use or inability to use the posting's information even if    Author has been advised of the possibility of such damage.
Posting
Normally no unless you set up some kind of L2 pseudowire.
Ven Taylor Thu, 12/01/2011 - 13:28
  • Bronze, 100 points or more
If your routers support the "connect" command, you can (like Joseph said) "bridge" those interfaces together and have an L2 vlan go across a wan connection.  We do it, but we have ASR's running over an RPR to bridge two Internet connections with HSRP.
Ven
sbempong Wed, 06/06/2012 - 06:48
Hi Ven Taylor, I am trying to configure two ASR1002 for bridging. We have point-to-point network between two sites. Can you please, send me your config. I have been searching Cisco Site but no luck.
Thank. Stephen
Ven Taylor Fri, 06/08/2012 - 06:13
Stephen:
Sure!  Here's an example of the interface configuration that allows three tagged vlans across a single physical link.
LAN <----> L3 switch <---->  ASR  <----> {WAN / RPR / WHATEVER} <----> ASR <----> L3 switch <----> LAN
interface GigabitEthernet0/1/0      <-- This is the trunk that connects to your local L3 switch.
no ip address
negotiation auto
cdp enable                                      <-- not necessary, but useful.
service instance 200 ethernet            <-- Ties it to the other side
  encapsulation dot1q 200                  <-- Tags the traffic
  bridge-domain 200                           <-- Bridges the whole thing together.
service instance 201 ethernet   <-- First "sub-vlan" for lack of a better term.
  encapsulation dot1q 201
  bridge-domain 201
service instance 210 ethernet  <-- Second "sub-interface".
  encapsulation dot1q 210
  bridge-domain 210
interface GigabitEthernet0/0/3  <-- This is your "WAN" interface - goes to the other ASR.
no ip address
negotiation auto
cdp enable
  bridge-domain 200
  bridge-domain 201
  bridge-domain 210
end
The other router will have the exact same configuration.  Once this is done, you'll have vlans 200, 201, and 210 trunking across a wan link.
Obviously, you can use any vlan schema, but remember, no IP addresses on these interfaces.  Just on the L3 switches at the distant ends of this connection.
hope this helps!
Ven
Amit Singh Thu, 12/01/2011 - 14:02
  • Cisco Employee,
Adding to Ven's post, you can either enable the IRB to achieve this or If you have an ASR1K router, you can use OTV with the latest realese due to be out soon.
Cheers,
-amit singh
sp2720401 Mon, 04/23/2012 - 18:32
One drawback that I found with OTV is that all of you clients must now run IGMPv3 for SSM. This is great unless you have dozens of senders/receivers for the same group.
Aries Fernandes Fri, 08/02/2013 - 01:41
  • Cisco Employee,
Inter VLAN communication is possible provided we have an L3 switch before the OTV ED device, or we can make the OTV ED device itself act as both the L3 device for the different vlans and for OTV router as well.
If this post is still un-answered  let me know, we can provide the solution for the concern posted above.
