12-01-2011 04:48 PM - edited 03-16-2019 08:21 AM
Hello almighty community!!
I´ve have the following scenario: CUCME (192.168.1.251) ======== SIP TRUNK ========= ELASTIX (192.168.1.3)
I found the following config which worked:
voice service voip
address-hiding
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol cisco
sip
dial-peer voice 3000 voip
destination-pattern 3...
session protocol sipv2
session target ipv4:192.168.1.3
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 6000 voip
description **Llamadas entrantes Troncal SIP**
translation-profile incoming AsteriskTrunk
destination-pattern 6000
codec g711ulaw
sip-ua
keepalive target ipv4:192.168.1.3
credentials username 5000 password wxyz realm 192.168.1.3
authentication username 5000 password wxyz
retry invite 4
retry response 3
retry bye 2
retry cancel 2
retry register 5
timers register 250
registrar ipv4:192.168.1.3 expires 3600
sip-server ipv4:192.168.1.3:5060
But the problem is that only CUCME is registering against Asterisk server, but not viceversa. The person whos managing the Asterisk server provide me this info
host=192.168.1.251
username=6000
secret=wxyz
Register String
6000:wxyz@192.168.1.251
, so i´m suppose to make something in CUCME to allow it to register, but as you may have notice by now, i´m not an expert, this is the first time i´m trying to acomplish this. How can i do this?. The result by the moment is that an IP phone connected to Asterisk can call a Cisco IP phone but when i try to call back from the Cisco IP phone to the Asterisk phone, it doesn´t work. The Asterisk PBX sees that a call is coming but it doesn´t establish it. Also, de Caller-ID
that Asterisk sees is 5000. I need that CID to be calling party number. For this last thing i was thinking to do this:
voice translation-rule 1
rule 1 /^3\(...\)/ /3\1/
voice translation-profile AsteriskCID
translate called 1
translation-profile outgoing AsteriskCID
But im not sure if that should work. Any help would be appreciated. Thanks
12-03-2011 07:47 PM
Hello! everyone who could give any idea about this subject? Thanks in advance.
12-05-2011 08:52 AM
Hello Andres..
Do you need to get the CME to become as a register server for the asterisk server?
With this config:
sip-ua
retry invite 4
retry response 3
retry bye 2
retry cancel 2
retry register 5
timers register 250
The CME will send sip registrations to 192.168.1.3
In order to convert the CME to a register server you need todo:
-ena
-config t
-voice service voip
-sip
-registrar server
With this the CME will accept SIP register messages coming in.
Hope it helps
12-05-2011 10:05 AM
Hola Richard!
Actually, i want to test both scenarios. The first one worked for me but then i try it using ip addressess on the data VLAN and stop working. Your answer is helpfull because clarifies me some doudbts but, i´m supposed to register the asterisk box on CME being like a register server using authentication, because the asterisk box is also sending me some credentials (
6000:wxyz@192.168.1.251). How could i perform this?. Thanks again for your help, and if you could tell me about this last issue, it will be great.
AF.
