Phone not picking up
Dec 2nd, 2011
I have a 7961 that when you lift the handset it does not pick up the calls but works fine on speaker. Anyone think this might be something other than the hardware failing?
Overall Rating: 5 (1 ratings)
acampbell Fri, 12/02/2011 - 07:43
  • Green, 3000 points or more
Sounds like the handset switch-hook is KAPUT
Alex
Rob Huffman Fri, 12/02/2011 - 07:45
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi there,
This is almost certainly a hardware problem with the Hookswitch. After deploying Cisco IP Phones for the last few years we (and many others) have found this to be the most common hardware problem. There is a "Best Practice" for cleaning the Hookswitch contacts (link below) that does work . Usually the phone has to be replaced/RMA'd.
If you don't have smartnet on the phone and you want to buy the parts to fix this let me know and I'll send a link
BestPractices for Cleaning and Troubleshooting Cisco IP Phone Hookswitch
From this interesting Tech note;
http://www.cisco.com/en/US/products/hw/phones/ps379/products_tech_note09186a00801c0810.shtml
Cheers!
Rob
acampbell Fri, 12/02/2011 - 07:48
WOW Rob, (+5 )
Self Cleaning Hookswitch Contacts
The hookswitch contacts design uses a wipe action to self-clean the contacts. Periods of nonuse of the phone allow air impurities such as dust and other contaminants to hinder contact performance, which results in intermittent operation. Press and release the hookswitch rapidly a dozen times or so to clean the contacts.
This is what Ive been doing for years.
I did not know about the document
Alex
LouiseDuguay Fri, 12/07/2012 - 06:56
Rob can you send the part list please when you have time.  OUr phones are:
7941, 7942, 7961, 7962, 7911, 6921
thanks
