Cisco ASA 5510 w/ AIP-SSM scan internal traffic too?
Dec 2nd, 2011
The Cisco IPS 4240 is a little too expensive and has too much "horse power" for our needs. I know I can connect the AIP-SSM to our ASA 5510 to scan traffic going through the ASA. What if I have my core router on our internal network send all traffic from all nodes to the ASA as the next hop for review by the AIP-SSM instead of sending the traffic directly to the internal destination? Is this recommended? Will it work? Have you tried it?
Saar Harel Fri, 12/02/2011 - 13:23
Hello Michael.
The IPS 4240 runs
250 Mbps
http://www.cisco.com/en/US/prod/collateral/vpndevc/ps5729/ps5713/ps4077/ps5768/prod_bulletin0900aecd8030c5da.html
The 5510 runs either
150 Mbps (with AIP SSM-10)
300 Mbps  (with AIP SSM-20)
http://www.cisco.com/en/US/products/ps6120/prod_models_comparison.html#~mid-range
This will work.
As far as expensive , try getting used / refurbished.
There are a lot of companies like Myriad supply etc etc.
Saar
Mike Thomas Fri, 12/02/2011 - 14:04
Thanks Saar
I not allowed to purchased used or refurbished equipment, but will give it another try.
Would you suggest pushing local node traffic destined for another local node through the AIP SSM-10 for inspection?
Saar Harel Fri, 12/02/2011 - 14:44
Hello Michael
The AIP SSM- has a limited Mbps so I would not recommend pushing the local traffic through it.
Saar
Mike Thomas Fri, 12/02/2011 - 14:46
Saar Harel - Thank you for your input. I'm going to try for the Cisco IPS 4240 via Myriad. Now to get management to change their decision on used equipment.
tiwang Mon, 12/05/2011 - 00:56
Hi again Michael
When you here write that it can handle so and so much traffic then are you aware of that you control which type of traffic you pass through the SSM module through access-lists? hereby you can reduce the amount of traffic needed to inspect to a small fragment of the total traffic
best regards /ti
Related Content
