You want to configure automatic phone registration by synchronizing phone user information by linking CUCM with AD. Is an API provided for solution interworking to automate phone registration in CUCM?
The content you are looking for has been archived. View related content below.
We're trying to use an Avigilon intercom with Broadsoft.Can these be configured as a generic intercom or is a configuration file required?
I have a bunch of 7821 phones on my network and I’m trying to replace a broken one. According to online courses all I should do is change the MAC address in the cucm and then save/apply etc then the new phone will register and it’s all good.But nothi...
I have a client that wants to deploy a site specific speed dial on their phones based on location for emergency notifications. The caveat is that many of the users log into phones using extension mobility and work at different sites which would requi...
I'm looking for some documentation or assistance with my Unity Root Certificate. It appears to have expired some time ago - looks to be self signed. Do I simply select "Root Certificate", then "Generate New Root Certificate"I am trying to get into Ci...
Hi GuysIs it possible to back up settings in the Webex control hub?Say one of our admins makes a massive mistake or deliberate, how would we restore our last known "good" configuration?Many thanks
Hi all,I'm trying to configure a trunk between my Cisco CUBES(ISR4431) to Genesys Cloud for a new implementationHas anybody made this challange ?It works with SIP/RTP and SIP/SRTP but when i switch to SIP with TLS it fails.TLS Handshake between Cube ...
Can someone point me to some documentation or an answer for converting the "dateTimeOrigination" entry in the CDR database into a real Date/Time format. The timestamps are in UTC format and we would like to make the conversion within an Excel spre...
Our Office space has a room kit plus that is connected to a windows computer that we can push slides from and present in meetings. We also have a DX-80 in our space to make calls across the connected network and have video conferences. Is there a way...
Hello people, Is there any document about the compatibility for expressway X8.11.4 with esxi 7.0 and esxi 7.0. su1 It is not clear on the document for installation x8.11, if I have understand correctly it is only supported with up to esxi 6.5 https:/...
We have a new MRA Expressway-E cluster running version X14.3.4 The secondary expressway is showing an error message every 15 seconds. It is reporting the gatekeeper timed out referencing the primary expressway (10.2.2.251) tvcs: Event="External Serve...
HiWe have Cisco Meeting Server and I have a problem while adding a participant to a meeting. I can dial the jabber device from CMS with the format "DirectoryNumber@CUCMAddress.com". How can I add a participant just with their Name ( whether the user ...
Good morning New user of a Cisco DX80, and novice, I would like to use it to join Zoom meeting sessions. The version is Room Os 9.15.17...etc and my Webex subscription is "Free". Access to Control Hub to add this function is unauthorized. Do you have...
We have a vg310 which is configured in call manager as sccp. When we connect endpoints like intercoms or analog phone sets, there are no issues with calls. However, when we connect one of those call boxes which places calls on behalf of multiple elev...
where can i dowload roomos cloud firmware for codec for example cs-kit-eq-c-k9 as per cisco document if the firmware 11.12.1 is for clould. because digit that comes after second decimail point is one.if any thing greater than one will be for on-prem...
Subject | Author | Posted |
02-25-2024 06:28 AM | ||
02-20-2024 09:48 AM | ||
02-05-2024 02:40 AM | ||
11-24-2023 10:51 PM | ||
11-21-2023 02:25 AM |
