Warning message
Cannot View/Edit phones in CUE 8.6.1
Answered Question
Dec 3rd, 2011
I have installed several systems with CUE 7.1 and was able to view and edit the phones and extensions via the CUE Web GUI. I am building a new system which is running CUE 8.6.1. When I login to the Web GUI, I do not see the phones or extensions at all. I have looked everywhere. Is there something else that needs to be installed or was that functionality removed?
Correct Answer by Rob Huffman about 5 years 8 months ago
Hi James,
Sadly this changed with the release of CUE 8.x;
Removal of Support for Cisco Unified Communications Manager Express GUI Functionality
Beginning with Cisco Unity Express 8.0, the Cisco Unity Express GUI no longer provides functionality for configuring Cisco Unified Communications Manager Express. Cisco recommends using Cisco Configuration Professional (CCP) to configure Cisco Unified Communications Manager Express.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel8_0/rel_notes/rel_notes.html#wp339722
Cheers!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Sat, 12/03/2011 - 07:54
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi James,
Cheers!
Rob
jameskuder Sat, 12/03/2011 - 10:43
That is lame. How do you tie mailboxes/users to the extensions/phones then?
jameskuder Sat, 12/03/2011 - 10:46
Which one do you recommend that I download for CME 8.0?
Related Content
