12-04-2011 07:49 PM - edited 03-16-2019 08:22 AM
Hi guys
We have a customer who is moving from 4 digit extension to a 6 digit plan. I have phones registered to call manager with 4 digit number already.
What is the best way to update the extension numbers to adhere new dial plan.
Can anyone share the ideas please.
I was trying to export the config. Update it. And import it. But what I have noticed is that in the export config directory number option doesn't even exists.
Thanks in advance.
12-04-2011 11:46 PM
Hi.
Using bulk administration and exporting all phones detail, you should obtain what you need.
I've already done this task in the past and I used this tool.
Carlo
12-04-2011 11:50 PM
hi
Thanks for your reply. I have tried that. This generates a .tar file which contains a csv file. When I open that file with excel. I get an error message saying the file is too big. May be row or column exceed the maximum value of 256.
I don't know what to do next.
12-05-2011 12:28 AM
Yes, Excel isn't man enough for this task - if you have users with multiple lines or lots of speed dials itexceeds the maximum columsn available.
You could try OpenOffice which seems better (in some ways - in others it's worse).
Either way you have to take care that the editor you use doesn't make unwanted edits (like inserting quotes or other formatting). I wrote some tools for our organisation for manipulating the CSVs for this type of task.
The other alternative is to use AXL. THe attached zip contains some java code you can extract to a directory, and create yourself an input file with lines like this:
1201,Test2PT,4444
This example would find line 1201 in partition Test2PT, and renumber it to '4444'.
You would run the program by going to a command prompt in the extracted directory and typing this (all one one line of course and using appropriate values to access your CUCM):
extensionsupdatedn.exe -username=ccmadministrator -password=mypassword -hostname=192.168.0.86 -input=ExtensionRemaptest.csv
You should of course do a couple of test extensions before doing a large batch.
Also allow plenty of time for testing etc, and go through anything else that might rely on extension numbers:
And so on..
Aaron
Please rate helpful posts..
03-22-2012 02:42 PM
Hi Aaron,
I have a huge number of DN to change and unfortunately your software returns me the following error:
C:\c>extensionsupdatedn -username=c -password=c -hostname=192.168.1.59 -input=e1.csv
Exception in thread "main" java.lang.NoClassDefFoundError: extensionsremapdn/ExtensionsRemapDN
Caused by: java.lang.ClassNotFoundException: extensionsremapdn.ExtensionsRemapDN
at java.net.URLClassLoader$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
Could not find the main class: extensionsremapdn.ExtensionsRemapDN. Program will exit.
Could you have a look ?
Kind regards
Thomas
04-03-2012 12:00 PM
I'm getting the same. Did you ever resolve this? Did you take another approach?
07-18-2012 10:26 AM
Hi Aaron,
Do you have any update about the error.. the system return me the same error:
Please, help us.
07-18-2012 12:42 PM
07-18-2012 07:57 PM
Hi Aaron,
This file works great... many thanks... i test it with 300 extensions and CUCM 6.0.1.2000-4 and Workss!!!
Thanks anew.
07-19-2012 01:07 AM
No problem!
Principal Engineer at Logicalis UK
Please rate helpful posts...
08-13-2012 03:58 AM
Hello Aaron,
how can I use your software, if the partition of the DN to remap is
I have tried in different ways, but none of them works:
1201,,4444
1201,"",4444
1201,'',4444
1201,
Regards.
07-22-2013 07:37 AM
Have you found a solution to this?
Partition is set to
02-25-2013 11:18 PM
Aaron... you 'da man!
You have no idea how helpful this is to me!
I found that there is a bug in 8.6 that it doesn't work with IP Communicator (fails with a "DND Option not available"). Ironically, I was just testing it against a experimental IP Communicator. When I tried a typical 7975.. it worked like a dream.
Thanks!
02-26-2013 09:57 AM
Glad it helped - if it's useful, please rate it :-)
10-10-2013 11:29 AM
A lot of thanks Aaron Harrison, I used your program and it worked great in a 8.6 CUCM versión (with 3,500 DNs).
In the other hand, after I made this DN upgrade, all the endusers remain with the last Directory Number and I can't upgrade them by BULk without changing the current user PIN.
Is there a way to upgrade the Directory Number in the EndUser without changing the current PIN? Similar as the DN procedure.
