Warning message
How to remove a Vlan-Group from a FWSM
Dec 5th, 2011
Hi All,
I am trying to remove a vlan group that is attached to an FWSM installed on a 6500 Switch
My original vlan group is as below
firewall module 8 vlan-group 40,41,42,43,44,45,46,47
I am now trying to remove vlan-group 45 with the below command
no firewall module 8 vlan-group 45
The problem is it is removing all the other vlan-groups as well. Could anybody advice what am I missing?
Also I understand that "firewall vlan-group" should be used to allocate vlan-groups to FWSM and "svclc vlan-group" should be used to allocate vlan-groups to the ACE. But for a vlan shared between the FWSM and the ACE, is it best to use a "firewall vlan-group" or a "svclc vlan-group" ??
Nilesh
Related Content
