Cisco 7613 Input queue
Dec 5th, 2011
I was wondering what could be a cause for the input queue drops and flushes number to be the same. If you have any commands I can run to do some troubleshooting that would be great. Thanks
Full-duplex, 1000Mb/s, media type is SX
  input flow-control is off, output flow-control is off
  Clock mode is auto
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 4d21h
  Input queue: 0/75/29981/29981 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
Overall Rating: 5 (2 ratings)
rsimoni Mon, 12/05/2011 - 10:10
input queue drops might indicate different problems depending on port configuration and other variable.
Can you attache the whole output  show interface x/x for us to see other important info to correlate with the input drops.
Also, do you see the drops on this port only or in others?
What about svi's do you see drops on those too?
How fast do the drop increment? Do you see a linear increment or in burts?
Besides drops and flushes do you see other counters increasing?
Riccardo
adibenedetto18 Mon, 12/05/2011 - 10:19
Show interface whole output
GigabitEthernet9/1 is up, line protocol is up (connected)
  Hardware is C6k 1000Mb 802.3, address is 001a.e31a.90c0 (bia 001a.e31a.90c0)
  Description: LAN connection
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Encapsulation 802.1Q Virtual LAN, Vlan ID  1., loopback not set
  Keepalive set (10 sec)
  Clock mode is auto
  30 second input rate 13000 bits/sec, 14 packets/sec
  30 second output rate 3000 bits/sec, 5 packets/sec
  L2 Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes
  L3 in Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes mcast
  L3 out Switched: ucast: 0 pkt, 0 bytes mcast: 0 pkt, 0 bytes
     4330076 packets input, 385044258 bytes, 0 no buffer
     Received 4207059 broadcasts (499570 IP multicasts)
     0 watchdog, 0 multicast, 0 pause input
     2052579 packets output, 151433237 bytes, 0 underruns
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
Also, do you see the drops on this port only or in others? Only this port
What about svi's do you see drops on those too? I do not see any drops on the svi
How fast do the drop increment? Do you see a linear increment or in burts? The drops look to be burst such as 5 or 10 in a period of time
Joseph W. Doherty Mon, 12/05/2011 - 11:14
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Might be SPD random drops or buffer failures.
Since you're running at gig, you might also just first try increasing the size of your input queue.
rsimoni Mon, 12/05/2011 - 12:59
I am afraid that those are not SPD drops as Gi9/1 is a L2 port and on L2 interfaces input drops/flushes have a different meaning as this traffic is not destined to the RP.
On L2 ports input drops might indicat fabric related drops (fabric flow control) which on releases after CSCsk83524 are also indicated by overruns, or physical buffers problem (oversubriscption).
To narrow this down can you send
show version
show module
show run int g9/1
show interfaces | include line protocol is|Input queue| rate
Riccardo
adibenedetto18 Tue, 12/06/2011 - 05:46
So I decided to replace the media from fiber to cat5e cable, drops seem to clear up. Thanks for your help.
