Upgrading ASR1002
Dec 5th, 2011
Hi there,
I have a problem upgrading my Cisco ASR1002. It is currently running on IOS image asr1000rp1-advipservicesk9.02.03.02.122-33.XNC2.bin. I have already uploaded a new image (asr1000rp1-advipservicesk9.03.02.02.S.151-1.S2.bin) and make the following changes on the router
ASR1002-02#sh run | i boot
boot-start-marker
boot system flash bootflash:asr1000rp1-advipservicesk9.03.02.02.S.151-1.S2.bin
boot-end-marker
ASR1002-02#
However, whenever I reboot the router, it still comes up with the previous image (asr1000rp1-advipservicesk9.02.03.02.122-33.XNC2.bin). The router is having 4GB RAM and the reason I want to upgrade the IOS image is that there is a software bug on the current IOS image. Anybody with an idea please?
AbuNasra
Leo Laohoo Mon, 12/05/2011 - 13:21
Try this:  boot system flash bootflash:/asr1000rp1-advipservicesk9.03.02.02.S.151-1.S2.bin
Leo Laohoo Mon, 12/05/2011 - 14:01
Can you post the output to "sh run | begin boot-start-marker" please?
Abdallah M Liguo Tue, 12/06/2011 - 03:40
Thanks for the response. It was not actually the boot sysntax, the problem was the IOS image itself which was corrupted. The observation from the console revealed the followings : -
Calculating SHA-1 hash...done
validate_package: SHA-1 hash:
        calculated 89246ab3:fcb13ad7:ba775a49:edac62f1:b0ad9776
        expected   bd99e71d:2ee880a3:6de2c964:76c1ae21:f203a1ab
SHA-1 hash doesn't match
boot: error executing "boot
bootflash:/asr1000rp1-advipservicesk9.03.02.02.S.151-1.S2.bin"
autoboot: boot failed, restarting...
We downloaded the IOS image again and it worked. Thanks for the support anyway.
zakid Sun, 04/01/2012 - 03:15
Can you please tell me what is the easiest way to upgrade IOS for ASR 1002 &1006
is the below right steps and if its right why we need to add the below ?
Why not directly the IOS image  asr1000rp1-adventerprisek9.02.01.00.122-33.XNA.bin
/auto/tftp-users/user/asr1000rp1-adventerprisek9.02.01.00.122-33.XNA.bin
Router# dir bootflash:
Directory of bootflash:/
11 drwx 16384 Dec 4 2007 04:32:46 -08:00 lost+found
86401 drwx 4096 Dec 4 2007 06:06:24 -08:00 .ssh
14401 drwx 4096 Dec 4 2007 06:06:36 -08:00 .rollback_timer
28801 drwx 4096 Mar 18 2008 17:31:17 -07:00 .prst_sync
43201 drwx 4096 Dec 4 2007 04:34:45 -08:00 .installer
13 -rw- 45977 Apr 9 2008 16:48:46 -07:00 target_support_output.tgz.tgz
928862208 bytes total (712273920 bytes free)
Router# copy tftp bootflash:
Address or name of remote host []? 172.17.16.81
Source filename []?
Destination filename [asr1000rp1-adventerprisek9.02.01.00.122-33.XNA.bin]?
Accessing
tftp://172.17.16.81//auto/tftp-users/user/asr1000rp1-adventerprisek9.02.01.00.122-33.XNA.bIN
Loading /auto/tftp-users/user/asr1000rp1-adventerprisek9.02.01.00.122-33.XNA.bin from
172.17.16.81 (via GigabitEthernet0):
[OK - 208904396 bytes]
208904396 bytes copied in 330.453 secs (632176 bytes/sec)
12 -rw- 208904396 May 28 2008 16:17:34 -07:00
928862208 bytes total (503156736 bytes free)
Router# config t
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)#boot system flash
bootflash:asr1000rp1-adventerprisek9.02.01.00.122-33.XNA.bin
Router(config)#config-reg 0x2102
Router(config)#exit
Router#show run | include boot
boot-start-marker
boot system flash bootflash:asr1000rp1-adventerprisek9.02.01.00.122-33.XNA.bin
boot-end-marker
Router# copy run start
Destination filename [startup-config]?
Building configuration...
[OK]
Router# reload
zakid Sun, 04/01/2012 - 22:17
Source filename []?
Accessing
Why i need to add the below line
or just put only the IOS
asr1000rp1-adventerprisek9.02.01.00.122-33.XNA.bin without
please confirm to me
Leo Laohoo Sun, 04/01/2012 - 22:46
I have never seen this before.  What you are loading is an IOS.  It's not even a bootstrap.  However the IOS you are loading is old.
Depending on what files you have in your bootflash, I wouldn't even configure a boot variable string unless you have two or more IOS files.
zakid Sun, 04/01/2012 - 23:32
Ok If have few questions
What is mean by
Consolidated Packages and Sub-Package ?
and the different between them
and if i want to upgrade the IOS from
asr1000rp1-adventerprisek9.03.03.00.S.151-2.S.bin
asr1000rp1-adventerprisek9.03.01.00.S.150-1.S.bin
To
asr1000rp1-adventerprise.03.05.01.S.152-1.S1.bin
The step for upgrading the IOS  version normal ?
copy tftp to boot flash by using normal tftp software like  3CDaemom becasue the IOS size 303 MB
Source filename []?
Destination filename [asr1000rp1-adventerprise.03.05.01.S.152-1.S1.bin] ?
Please confirm to me
Leo Laohoo Mon, 04/02/2012 - 14:53
That's correct.  Copy the IOS from your TFTP server to either the flash or bootflash.  If you only have ONE (1) IOS in the bootflash or flash then you don't need to bother about the boot variable string.
zakid Mon, 04/02/2012 - 22:53
But in case i have already one IOS and i need to add another one and i want to boot from the new one
in that case i need to add the below
Router# config t
bootflash:asr1000rp1-adventerprise.03.05.01.S.152-1.S1.bin
Router(config)#exit
boot-start-marker
boot system flash bootflash:asr1000rp1-adventerprise.03.05.01.S.152-1.S1.bin
boot-end-marker
[OK]
Router# reload
So the router will boot from the new image right
please confirm to me that
Cisco.Support1 Mon, 01/02/2017 - 22:38
Just in case anyone comes across this later. You need to add the "boot system flash:/" keyword. eg:
Router01#sh run | i boot
boot-start-marker
boot system flash:/
boot system flash bootflash:asr1000rp1-adventerprisek9.03.16.04a.S.155-3.S4a-ext.bin
boot-end-marker
Router01#
