12-05-2011 02:21 PM
I'm having trouble getting SSL Offloading to work correctly in my test environment. I built a test web server and can get HTTP to load balance just fine. In the same context I am doing SSL offloading. Within Wireshark I can see the source making it to the ACE and then the ACE communicating with the web server but the connection stops after the web server sends an ACK packet to the nat address on the ACE. The connection eventually RST. Here's the configuration:
ACE/VC_test# sh run
Generating configuration....
crypto chaingroup INTERMED_GODADDY
cert intermediate.pem
access-list Allow_VLAN205_Traffic line 15 extended permit tcp any host 10.90.205
.10 eq https
access-list Allow_VLAN205_Traffic line 18 extended permit tcp any host 10.90.205
.10 eq www
probe icmp ICMP_PROBE
description PROBE INTENDED FOR LOAD BALANCING TRAFFIC
interval 2
faildetect 2
passdetect interval 2
passdetect count 5
rserver host WEB01
ip address 10.90.10.46
inservice
rserver host WEB02
ip address 10.90.10.47
inservice
serverfarm host SF_test
description TEST SERVER FARM
probe ICMP_PROBE
rserver WEB01
inservice
rserver WEB02
parameter-map type ssl SSL_TERM_PARAM
cipher RSA_WITH_3DES_EDE_CBC_SHA
cipher RSA_WITH_AES_128_CBC_SHA priority 2
cipher RSA_WITH_AES_256_CBC_SHA priority 3
rehandshake enabled
sticky http-cookie SSL_PERS SFTEST_STICKY
cookie insert browser-expire
serverfarm SF_test
action-list type modify http SSL_ACTIONLIST
ssl url rewrite location "lb\.website\.org\.*"
ssl-proxy service SSL_PROXY_SSLTEST
key lbprivatekey.pem
cert lbservercert.pem
ssl advanced-options SSL_TERM_PARAM
class-map match-all HTTPS_CLASS
2 match virtual-address 10.90.205.10 255.255.255.0 tcp eq https
class-map type management match-any Remote-Mgmt_Class
2 match protocol ssh any
3 match protocol https any
4 match protocol icmp any
5 match protocol snmp any
6 match protocol xml-https any
class-map match-all VIP_CLASS
2 match virtual-address 10.90.205.10 tcp eq www
policy-map type management first-match Remote-Mgmt_Policy
class Remote-Mgmt_Class
permit
policy-map type loadbalance http first-match HTTP_POLICY
class class-default
serverfarm SF_test
policy-map type loadbalance http first-match SSL_POLICY
class class-default
sticky-serverfarm SFTEST_STICKY
action SSL_ACTIONLIST
policy-map multi-match HTTPS_VIPs
class HTTPS_CLASS
loadbalance vip inservice
loadbalance policy SSL_POLICY
loadbalance vip icmp-reply active
nat dynamic 30 vlan 205
ssl-proxy server SSL_PROXY_SSLTEST
policy-map multi-match VIPs
class VIP_CLASS
loadbalance policy HTTP_POLICY
class class-default
nat dynamic 20 vlan 205
interface vlan 200
interface vlan 205
description TEST
ip address 10.90.205.11 255.255.255.0
no normalization
access-group input Allow_VLAN205_Traffic
nat-pool 20 10.90.205.250 10.90.205.254 netmask 255.255.255.0 pat
nat-pool 30 10.90.205.240 10.90.205.245 netmask 255.255.255.0 pat
service-policy input VIPs
service-policy input HTTPS_VIPs
no shutdown
ip route 0.0.0.0 0.0.0.0 10.90.205.1
Could the problem be the ssl rewrite?
Solved! Go to Solution.
12-06-2011 08:56 AM
I think I spotted another problem in your configuration your HTTPS VIP is using a /24 mask instead of 32.
Remove the current line and enter the following line instead:
2 match virtual-address 10.90.205.10 255.255.255.255 tcp eq https
To answer your question... yeah makes no sense using 443 in your backend servers for what you're trying to accomplish, this would be called End-to-End SSL and it would add extra processing to your servers.
__ __
Pablo
12-05-2011 11:34 PM
In order for SSL termination to work correctly you need to specify the clear text port used in the backend servers otherwise the ACE will make the call to the servers using the same port configured for the VIP.
Try removing the rservers from the serverfarm first and then add the clear text port number next to them, it would end up
looking like this:
probe ICMP_PROBE
rserver WEB01 80
inservice
rserver WEB02 80
__ __
Pablo
12-06-2011 08:48 AM
Unfortuantely that didn't work for me. Since SSL offloading is done at the ACE there is no reason to have the web server answering on port 443, correct?
12-06-2011 08:56 AM
__ __
Pablo
12-06-2011 09:26 AM
That did it! Now https is working. Thanks!
Is it possible to have regular HTTP on this context or is it best practice to put https on it's own context?
UPDATE: I just got HTTP load balancing as well on the same context.
