Warning message
UCS Question IP Migration
Answered Question
Dec 5th, 2011
Hi All,
Just a simple Q.
I got a 2 unit of UCS in my infra.
I need to change the IP address from Private IP Address to Public IP Address.
From what I see, I need to change below IP Address.
1. Management Interface IP Address & Cluster IP address
2. Management IP Pool
Questions:
1. What else IP Address that need to be change? To double verify on my finding.
2. If I change those IP Address, will it affected to the virtual machine inside the UCS?
3. Any other things I should take care of?
Your assistance is much appreciated.
Thanks.
Correct Answer by rewilkin about 5 years 8 months ago
Fantasy24, you are correct on the IP's that you need to change and it will not affect your VM's. The mgmt IP's are for the mgmt of the FI's only and have no effect on the host or VM IP's.
Overall Rating: 5 (1 ratings)
Correct Answer
rewilkin Tue, 12/06/2011 - 03:01
