ASA 5505 transparent mode setup
Dec 5th, 2011
Hi guys,
i need to configure a ASA 5505 in transparent mode.
learned from Internet, my configuration is :
int e0/0 --- vlan 1---->nameif outside
int e0/4 --- vlan 2------> nameif inside
gloable ip is 172.17.104.10 255.255.255.0
http server enable
http 172.17.104.0 255.255.255.0 inside
when i connect the outside interface to one PC with ip addr 172.17.104.194
my PC connect to inside interface with ip 172.17.104.249
cannot ping each other even when i set rules as permit any any on both direction
varrao Tue, 12/06/2011 - 02:03
  • Red, 2250 points or more
Can you send me an output of "show run interface", moreover you have the https server enabled on the inside interface and not on the outside.
Varun
p0663843ccie Tue, 12/06/2011 - 03:44
hi man thanks for reply the issue was resolved. one vlan was down i did not notice
Sent from my iPhone
