ā12-06-2011 07:03 AM - edited ā03-07-2019 03:45 AM
hi,
we are getting this log from Catalyst 4500. What kind of problem should it be?
Dec 6 11:18:57.800: %C4K_RKNOVA-4-INVALIDTOKENEXPIRED: STANDBY:(Suppressed 100 times)Expired token 28389 in the invalid token list (NumEntries: 6) of type IrmPortId other id == 4294967288
ā12-06-2011 07:55 AM
Hi Muhammed,
In most cases this error messages will appear if wccp is configured and it is not supported by the supervisor engine installed.
There are some cosmetic bugs related to this as well.
Could you please post the show version & show module output?
Cheers
Somu
ā12-06-2011 11:25 PM
sh ver
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSAL-M), Version 03.01.01.SG RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Tue 14-Dec-10 21:30 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2010 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
Image text-base: 0x1009E914, data-base: 0x13B71550
ROM: 15.0(1r)SG1
Jawa Revision 7, Snowtrooper Revision 0x0.0x15
4500-NEW uptime is 24 weeks, 19 hours, 21 minutes
Uptime for this control processor is 24 weeks, 16 hours, 4 minutes
System returned to ROM by reload
System restarted at 18:19:42 EEST Tue Jun 21 2011
Running default software
Last reload reason: Reload command
License Information for 'WS-X45-SUP7-E'
License Level: ipbase Type: Permanent
Next reboot license Level: ipbase
cisco WS-C4510R+E (MPC8572) processor (revision 8) with 786516K/16384K bytes of memory.
Processor board ID FOX1513H1HM
MPC8572 CPU at 1.5GHz, Supervisor 7
Last reset from Reload
43 Virtual Ethernet interfaces
102 Gigabit Ethernet interfaces
20 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
sh module
Chassis Type : WS-C4510R+E
Power consumed by backplane : 40 Watts
Mod Ports Card Type Model Serial No.
1 12 10GE SFP+ WS-X4712-SFP+E CAT1511L0DT
2 6 1000BaseX (GBIC) WS-X4306-GB JAE1048G5YV
5 4 Sup 7-E 10GE (SFP+), 1000BaseX (SFP) WS-X45-SUP7-E CAT1515L03L
6 4 Sup 7-E 10GE (SFP+), 1000BaseX (SFP) WS-X45-SUP7-E CAT1515L00L
9 48 10/100/1000BaseT (RJ45) WS-X4548-GB-RJ45 JAE1049GJNX
10 48 10/100/1000BaseT (RJ45) WS-X4548-GB-RJ45 JAE1049GL3W
M MAC addresses Hw Fw Sw Status
1 0026.0b79.f246 to 0026.0b79.f251 1.1 Ok
2 0016.c75e.ff20 to 0016.c75e.ff25 4.2 Ok
5 6400.f1e6.ea00 to 6400.f1e6.ea03 1.0 15.0(1r)SG1 03.01.01.SG Ok
6 6400.f1e6.ea04 to 6400.f1e6.ea07 1.0 15.0(1r)SG1 03.01.01.SG Ok
9 0012.d972.a5c0 to 0012.d972.a5ef 2.3 Ok
10 0012.d972.a410 to 0012.d972.a43f 2.3 Ok
Mod Redundancy role Operating mode Redundancy status
5 Standby Supervisor SSO Standby hot
6 Active Supervisor SSO Active
System Failures:
Power Supply: bad/off (see 'show power')
sh ip wccp
Global WCCP information:
Router information:
Router Identifier: 1.1.1.199
Protocol Version: 2.0
Service Identifier: 61
Number of Service Group Clients: 1
Number of Service Group Routers: 2
Total Packets s/w Redirected: 0
Process: 0
CEF: 0
Redirect access-list: WCCP_LAN_TO_WAN_61
Total Packets Denied Redirect: 8594844
Total Packets Unassigned: 0
Group access-list: -none-
Total Messages Denied to Group: 0
Total Authentication failures: 0
Total Bypassed Packets Received: 0
Service Identifier: 62
Process: 0
CEF: 0
Redirect access-list: WCCP_WAN_TO_LAN_62
Total Packets Denied Redirect: 0
ā09-13-2012 06:51 AM
I am seeing the same error in the logs of a box I deployed last night. There is no WCCP configured on this device. I am running cat4500e-universalk9.SPA.03.03.00.SG.151-1.SG.bin code with redundent Sup 7L-E 10GE (SFP+).
Anyone have another thought on what this could be from. My install is a very simple L2 access switch.
Pat
ā05-08-2012 07:31 PM
Hi, I have the same entry appearing in my logs, did you find a resolution for this topic?
Cheers,
Brendan
ā08-24-2012 07:10 AM
Upgrade to cat4500e-universalk9.SPA.03.03.00.SG.151-1.SG.bin has resolved the issue. Indeed i believe it was due to wccp.
ā10-01-2012 10:59 AM
I'm running cat4500e-universalk9.SPA.03.03.00.SG.151-1.SG.bin with no WCCP.
The release notes indicate this is a cosmetic issue related to OIR of linecards.
Reboot and it will most likely clear. I haven't had a chance to reboot and verify yet.
ā05-28-2013 10:25 AM
patrickh99,
Did you ever reboot your switch? Did it clear up the error message? The reason I ask is this recently appeared on one of my 4507's. I'm running 03.03.02.SG.151-1.SG2.
Thx,
Tone
ā12-09-2016 01:45 AM
I don't have wccp enabled, but still encountering this issue.
ā10-27-2016 08:44 AM
Same issue here, logs are full of error.
063435: 004230: Oct 27 15:07:51.431 UTC: %C4K_RKNOVA-4-INVALIDTOKENEXPIRED: STANDBY:(Suppressed 100 times)Expired token 3221 in the invalid token list (NumEntries: 6) of type IrmPortId other id == 4294967287
063436: 004231: Oct 27 15:12:54.433 UTC: %C4K_RKNOVA-4-INVALIDTOKENEXPIRED: STANDBY:(Suppressed 100 times)Expired token 3221 in the invalid token list (NumEntries: 6) of type IrmPortId other id == 4294967287
063437: 004232: Oct 27 15:17:57.435 UTC: %C4K_RKNOVA-4-INVALIDTOKENEXPIRED: STANDBY:(Suppressed 100 times)Expired token 3221 in the invalid token list (NumEntries: 6) of type IrmPortId other id == 4294967287
063438: 004233: Oct 27 15:23:00.437 UTC: %C4K_RKNOVA-4-INVALIDTOKENEXPIRED: STANDBY:(Suppressed 100 times)Expired token 3221 in the invalid token list (NumEntries: 6) of type IrmPortId other id == 4294967287
Any definitive root cause discovered here? cat4500e-universalk9.SPA.03.03.02.SG.151-1.SG2.bin
