12-07-2011 10:59 AM - edited 03-07-2019 03:47 AM
Hi All,
Is it possible to have etherchannel across 2 switches? As an example, having a server with 2 ports connect, 1 port to Switch-A and the other to Switch-B and then use those two links on the sepatate switches but to the same server to form an Etherchannel.
The Switch-A and Switch-B are 3560 series
Any thoughts and or comments much appreciated.
12-07-2011 11:05 AM
Unfortunately not with 3560 switches. The etherchannel cannot be spread across both chassis. To be able to have an etherchannel across 2 chassis you need either -
1) 3750 switch stack
2) 6500 VSS
3) Nexus VPC
with all other switches the restriction is all etherchannel ports must be on the same switch.
Jon
12-07-2011 01:13 PM
Hi Jon,
Thanks for the confirmation.
