12-07-2011 04:09 PM - edited 03-01-2019 10:11 AM
I have two nexus 5548's configured as a vPC peers and two ucs 6120's configure in a cluster. The 5548's are connected to two catalyst 6500 via trunks that are in a VSS configuration. My question is, i have the ucs 6120 managment 0 ports connected to the 5k's, 6120-A mgmt0 to 5k-1 and 6120-B to 5k-2, everytime i fail the ucs 6120-A (primary) i lose ping to the cluster ip and can't manage ucs 6120-B at all even though it is pingable. Below are snippets on how the management ports are configured on the 5K's. Any Idea's?
nx5k-1
interface Ethernet1/13
description 6120-A:MGMT0
switchport mode trunk
switchport trunk native vlan 100
switchport trunk allowed vlan 100
speed 1000
channel-group 12 mode active
interface port-channel12
description 6120:A:MGMT
vpc 12
spanning-tree port type network
speed 1000
nx5k-2
description 6120-B:MGMT0
speed 1000
description 6120:B:MGMT
vpc 12
speed 1000
12-07-2011 04:47 PM
you need to configure UCS management failover monitoring
http://www.cisco.com/en/US/docs/unified_computing/ucs/sw/gui/config/guide/2.0/b_UCSM_GUI_Configuration_Guide_2_0_chapter_0101010.html#concept_8EFB3986365C4F69A6C3B9BBC14D16FE
12-07-2011 08:25 PM
nks for the quick reply. I have setup management failover monitoring but when i failover from 6120-A to 6120-B i still lose ping to the cluster ip and all of management.
12-08-2011 04:58 AM
How do you have it configured? It can take a few minutes or more depending on the configuration
12-08-2011 05:01 AM
Wait a minute, I just noticed that you have your management interfaces in a port channel and vPC?
Those should be setup as standalone access ports, there isn't a UCS side configuration to place those into a port channel. They are on different Fabric Interconnects anyway.
