ā12-08-2011 04:46 AM - edited ā03-01-2019 07:02 AM
Please see diagram attached.We need to connect two datacentres and run OTV .two 10 g links between datacentres are dark fiber and configured in Layer 3 port channel ahd also a OTV join interface.due to some requiremnets OTV vdc has vPC running between each site locally.I have posted my config, please review and see if it can work.I know its not recommend way but we have certain requirmrnts to run this way.
DC1
7k1
interface port-channel100
description "OTV join link"
ip address 1.1.1.1/30
interface Overlay0
otv join-interface port-channel100
otv extend-vlan 20
otv use-adjacency-server 1.1.1.1 1.1.1.2 unicast-only
otv adjacency-server unicast-only
no shutdown
ip route 0.0.0.0/0 1.1.1.2
otv site-identifier 0001.0001.0001
7K2
same config
DC2
7K1
ip address 1.1.1.2/30
interface Overlay0
otv extend-vlan 20
otv use-adjacency-server 1.1.1.2 1.1.1.1 unicast-only
no shutdown
ip route 0.0.0.0/0 1.1.1.1
otv site-identifier 0002.0002.0002
7K2
same config
ā01-14-2012 06:11 PM
Make sure you PVC domains are different, also there is no local site vlan, you need this for the two 7ks to select an AED
ā01-15-2012 06:59 AM
Hi thanks for reply,
vPC domain in both DC's are diffrent.Can you explain bit further that why is necessary , not to have site local vlan?
Currently site local vlan 99 has been configured in all the VDC's in both datacentres.
ā01-15-2012 09:05 AM
The two 7K's elect an authoritative edge device over the site vlan, the active AED will forward traffic (assuming you are not loadbalancing). If you don't have a local site vlan it will simply not work, i don't even think the overlay interface will come up without it.
Martijn
ā01-15-2012 09:47 AM
Like MWLANGEDIJK said, you need to have site VLAN for OTV edge device to elect AED. I don't see the OTV internal interface configuration and I cannot provide any advise. If you use the command show otv, you can see the status of the site-vlan. Here is a sample output from my lab (BTW, I am using multicast, but the site-vlan config is the same as unicast):
Pri-DC-OTV-1# sh otv
OTV Overlay Information
Site Identifier 0000.0000.0100
Overlay interface Overlay0
VPN name : Overlay0
VPN state : UP
Extended vlans : 10-11 20-21 30-31 40-41 (Total:8)
Control group : 239.0.0.1
Data group range(s) : 232.1.1.0/24
Join interface(s) : Po1121 (10.10.101.2)
Site vlan : 111 (up)
AED-Capable : Yes
Capability : Multicast-Reachable
One really import information about site-vlan, it should not be extended over OTV, it is local to each site.
Below is the command guide for your reference:
HTH,
jerry
ā01-15-2012 11:51 AM
The site VLAN is configured and OTV is working fine, except below duplicate address error message.not sure why this error is generated.its the MAC add of int e3/1 which is part of int po100(join int).
""2012 Jan 13 14:34:07 otv2 %ISIS_OTV-4-LAN_DUP_SYSID: isis_otv-default [28740] L1 LAN IIH - Duplicate system ID 4055.3927.d1c2 detected over Overlay0 from 4055.3927.d1c2"""""
otv2(config-if-overlay)# sh otv
Site Identifier 0002.0002.0002
VPN name : Overlay0
VPN state : UP
Extended vlans : 101 103 105 107 191 193 200 300-303 (Total:11)
Join interface(s) : Po100 (1.1.1.2)
Site vlan : 1001 (up)
AED-Capable : Yes
Capability : Unicast-Only
Is Adjacency Server : Yes
Adjacency Server(s) : 1.1.1.2 / 1.1.1.1
otv2(config-if-overlay)# sh otv isis
ISIS process : default
VPN: Overlay0
System ID : 4055.3927.d1c2 IS-Type : L1
SAP : 439 Queue Handle : 12
Maximum LSP MTU: 1392
Graceful Restart enabled. State: Inactive
Last graceful restart status : none
Metric-style : advertise(wide), accept(narrow, wide)
Area address(es) :
00
Process is up and running
VPN ID: 53
Incremental update routes during SPF run
Stale routes during non-graceful controlled restart
Interfaces supported by OTV-IS-IS :
Overlay0
Authentication type and keychain haven't been configured
Authentication check is specified
Address family IPv4 unicast :
Number of interface : 1
Adjacency check disabled
Distance : 115
Address family IPv6 unicast :
Distance : 115
Address family MAC unicast :
Distance : 115
L1 Next SPF: Inactive
-otv2(config-if-overlay)# sh int e3/1
Ethernet3/1 is up
Dedicated Interface
Belongs to Po100
Hardware: 10000 Ethernet, address: 4055.3927.d1c2 (bia ccef.4823.b349)
Description: * OTV
MTU 9216 bytes, BW 10000000 Kbit, DLY 10 usec
Encapsulation ARPA
full-duplex, 10 Gb/s, media type is 10G
Beacon is turned off
Auto-Negotiation is turned off
Input flow-control is off, output flow-control is off
Rate mode is dedicated
Switchport monitor is off
EtherType is 0x8100
Last link flapped 13:40:35
30 seconds input rate 5040648 bits/sec, 766 packets/sec
30 seconds output rate 54894728 bits/sec, 4642 packets/sec
Load-Interval #2: 5 minute (300 seconds)
input rate 7.63 Mbps, 894 pps; output rate 32.70 Mbps, 2.83 Kpps
L3 in Switched:
ucast: 0 pkts, 0 bytes - mcast: 0 pkts, 0 bytes
L3 out Switched:
RX
3094425998 unicast packets 353521 multicast packets 19 broadcast packets
3094779539 input packets 3053498432578 bytes
284395082 jumbo packets 0 storm suppression packets
0 runts 0 giants 1 CRC 0 no buffer
1 input error 0 short frame 0 overrun 0 underrun 0 ignored
0 watchdog 0 bad etype drop 0 bad proto drop 0 if down drop
0 input with dribble 0 input discard
0 Rx pause
TX
11996399744 unicast packets 353521 multicast packets 21 broadcast packets
11996753286 output packets 17406552054383 bytes
433788413 jumbo packets
0 output error 0 collision 0 deferred 0 late collision
0 lost carrier 0 no carrier 0 babble 0 output discard
0 Tx pause
7 interface resets
ā01-15-2012 05:59 PM
What software version? 5.2(1)?
jerry
ā01-16-2012 04:50 AM
yes, it is 5.2(1)
Regards.
ā01-16-2012 03:43 PM
ā10-23-2013 08:12 PM
Hi Jerry,
I think I am facing the same bug in 6.1.2
Could you send me a copy of the bug description? It apprears to be in a protected section of bug tool.
Thank you in advance.
Cheers,
Boris
ā10-28-2013 06:50 AM
Hi Boris,
Bug, CSCtw82691 is already fixed in NX-OS 5.2(3a). I don't believe your issue is the same.
jerry
