Warning message
Force Authorization code in CME
Dec 8th, 2011
Dear all,
i need help is there any way to configure FAC in CME 7.0.as i need to block international access on pots & voip dail peers  using FAC code  all the time not only after office hrs.
i have gone through all the doc related to call blocking but while configuring the same. i face below mentioned issue
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeblock.html
1)  how can I block the dial peer for all times. The option I have is to restrict only during specified timings.
2) According to the document I configured "login" in the template, and the login does work, but it does not matter whether I am logged in or not, the calls are still going through.
I would appreciate if some one has alreday done this & help me out ..
owaisqadri Fri, 12/09/2011 - 01:37
I know this feature is avialable in 8.5 version , but is there any workaround for this in 7.0 version.
owaisqadri Fri, 12/09/2011 - 02:11
Thanks Ronak for your valuable inputs..
but when i try to put below mentioned cmmd in my cme  router there is no such cmmd available my CME IOS verison is 15.0 M7
call application voice
ronpatel Fri, 12/09/2011 - 02:48
  • Blue, 1500 points or more
hi
Command is changed use following command.
Router(config)#application
Router(config-app)# service ?
Ronak Patel
