12-08-2011 09:08 PM
Hi all
Does anyone here have an idea to why i couldn't export one network prefix from VRF A to VRF B, but I could successfully export a prefix from VRF B into VRF A?
I have attached the stats and config here.
Any advices are welcome and appreciated for your help.
Solved! Go to Solution.
12-10-2011 05:35 PM
Hi Guys,
My 10 cents here.
Robo,
After I read all sorts of articles relating to VRF lite, VRF route leaks are not easily perform by export map with additive keyword. it can accept the RT exchange between VRFs via the first RT or original RT.As it is a form of VRF-lite, the extended communities are not exchanged by MPLS Core ( it is lack of "neighb xxxx send-community extended/both" under AF vpnv4 pointing towards core), the 2nd additive extended community RT should not be exported successfully. However, I have my half "successful" example there..... why....?
This is not true. whether its a VRF-Lite or a full blown L3 MPLS VPN, the way the communites work in BGP are the same. Allow me to explain a bit here.
With VRF-Lite although you dont have VPNV4 peering with another BGP speaker the route-targets still end up in the sAFI table(vpnv4) as these RT's are extended communities and must be available in MP-BGP to be picked up by other VRF's by using import option.
You would use the "neighb xxxx send-community" only when you have vpnv4 bgp peers . but in this since we are talking about VRF-Lite this is not needed unless these prefixes need to be transported to a another router elsewhere.
I have labbed this for you to show what I mean and pasting it here
R1#sh run
hostname R1
ip cef
ip vrf A
rd 100:1
route-target export 100:1
route-target import 100:1
route-target import 300:3
ip vrf B
rd 200:1
export map B-to-A
route-target export 200:1
route-target import 200:1
interface Loopback1
ip address 1.1.1.1 255.255.255.255
interface Loopback22
ip vrf forwarding B
ip address 22.22.22.22 255.255.255.255
interface GigabitEthernet2/0.10
encapsulation dot1Q 10
ip vrf forwarding A
ip address 10.1.1.1 255.255.255.0
interface GigabitEthernet2/0.20
encapsulation dot1Q 20
ip vrf forwarding B
ip address 20.1.1.1 255.255.255.0
router bgp 6500
no synchronization
bgp log-neighbor-changes
no auto-summary
address-family ipv4 vrf B
redistribute connected
no synchronization
exit-address-family
address-family ipv4 vrf A
no synchronization
exit-address-family
access-list 10 permit 22.22.22.22
route-map B-to-A permit 10
match ip address 10
set extcommunity rt 300:3 additive
end
R1# sh ip bgp vpnv4 vrf B 22.22.22.22
BGP routing table entry for 200:1:22.22.22.22/32, version 8
Paths: (1 available, best #1, table B)
Not advertised to any peer
Local
0.0.0.0 from 0.0.0.0 (1.1.1.1)
Origin incomplete, metric 0, localpref 100, weight 32768, valid, sourced, best
Extended Community: RT:200:1 RT:300:3 <<< Has the additive RT added
mpls labels in/out 18/nolabel(B)
R1#
R1#sh ip route vrf A
Routing Table: A
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
22.0.0.0/32 is subnetted, 1 subnets
B 22.22.22.22 is directly connected, 00:12:58, Loopback22 << imported here
10.0.0.0/24 is subnetted, 1 subnets
C 10.1.1.0 is directly connected, GigabitEthernet2/0.10
R1#
R1#sh ip route vrf B
Routing Table: B
20.0.0.0/24 is subnetted, 1 subnets
C 20.1.1.0 is directly connected, GigabitEthernet2/0.20
C 22.22.22.22 is directly connected, Loopback22 <<<< Exporting this prefix
R1#
R1#sh route-map
route-map B-to-A, permit, sequence 10
Match clauses:
ip address (access-lists): 10
Set clauses:
extended community RT:300:3 additive <<< Additive keyword for exporting this to vpnv4 table
Policy routing matches: 0 packets, 0 bytes
R1#sh ip access-lists
Standard IP access list 10
10 permit 22.22.22.22 (2 matches)
R1#
BTW: Robo , I am just going thru your config now.
Kishore
12-10-2011 08:24 PM
Hi Kishore
Yes even that what surprises me too..I also labbed it and everything works cool..My earlier explaination in the start of the post was on a different context I was thikning off which did not hold good here
Hi Robo
The alternative solution which you are thinking is a lot more same as the current setup except for instead of using additivie extcommunity we want to use just replace the community value . Well we can try it for sure but I think its better to find out why the additive community was not being applied to the eBGP route in the first place..
Also I was thinking why don't we use an import-map with two terms-one to select the local VRF's targetted RTs and other to select the other VRF's RT with selective prefix list..It will solve our purpose with ease and also get us rid from the export-map config under VRFs
E.G
ip vrf CEA
rd 6413:1
import map CEA_IN
route-target export 64513:100
route-target import 64513:100
route-target import 64513:200
ip vrf CEB
rd 64513:2
import map CEB_IN
route-target export 64513:200
route-map CEA_IN permit 10
match extcommunity CEA
route-map CEA_IN permit 20
match ip address prefix-list 100
match extcommunity CEB
route-map CEB_IN permit 10
route-map CEB_IN permit 20
match ip address prefix-list 200
ip extcommunity-list standard CEA permit rt 64513:100
ip extcommunity-list standard CEB permit rt 64513:200
ip prefix-list 100 seq 5 permit 10.0.201.1/32
ip prefix-list 200 seq 5 permit 10.0.101.1/32
R2#sh ip route vrf CEA
Routing Table: CEA
10.0.0.0/8 is variably subnetted, 5 subnets, 2 masks
C 10.0.10.0/30 is directly connected, FastEthernet0/0
C 10.0.111.1/32 is directly connected, Loopback10
B 10.0.101.1/32 [20/0] via 10.0.10.2, 00:04:49
S 10.0.151.1/32 [1/0] via 10.0.10.2
B 10.0.201.1/32 [20/0] via 10.0.20.2 (CEB), 00:04:34
R2#sh ip route vrf CEB
Routing Table: CEB
10.0.0.0/8 is variably subnetted, 4 subnets, 2 masks
C 10.0.20.0/30 is directly connected, FastEthernet0/1
B 10.0.101.1/32 [20/0] via 10.0.10.2 (CEA), 00:04:52
B 10.0.201.1/32 [20/0] via 10.0.20.2, 00:04:37
S 10.0.251.1/32 [1/0] via 10.0.20.2
R2#
As shown above this helps to get the eBGP routes learnt in another VRF to be imported in separate VRF woth ease..
Hope this helps to provide more clarity on this issue. Please let me know for any clarifications.
Varma
12-08-2011 10:10 PM
Can you please share the configs please.
Smitesh
12-08-2011 11:14 PM
Hi CSCO11020330
With regards to your issue of the route 10.130.100.0 not being imported into VRF I9003:Mgmt below is my finding:
The Route 10.130.100.0 has a VPN Memebership to VRF V1010:LLL via RT 17669:1010 and received as an EBGP route across MPLS VPN Cloud and hence imported into VRF V1010:LLL and not into VRF I9003:Mgmt
ip vrf V1010:LLL
rd 17669:1010
export map V1010:LLLtoI9003:Mgmt
route-target export 17669:1010
route-target import 17669:1010
route-target import 17669:900311
PRSIN2MPLSR01#sh ip bgp vpnv4 vrf V1010:LLL 10.130.100.0
BGP routing table entry for 17669:1010:10.130.100.0/24, version 5908
Paths: (1 available, best #1, table V1010:LLL)
65504 65500 65001 4445 4445 65500 65501
10.130.253.1 from 10.130.253.1 (10.255.48.17)
Origin IGP, localpref 200, valid, external, best
Extended Community: RT:17669:1010
The Export Route-Map which is being applied under the two VRF configs only applies to exported routes from the local MPLS PE and the route in question is being imported across MPLS-VPN cloud and that's why the export-map does not works..
However it works for Prefix 10.8.0.0 as its a local Static Route which is being redistributed into VRF I9003:Mgmt and gets tagged with the RT 17669:900311 which is allowed under the Export-Map I9003:MgmttoV1010:LLL and further imported into VRF V1010:LLL via the import RT configuration under VRF
ip route vrf I9003:Mgmt 10.8.0.0 255.255.0.0 10.8.63.4
To fix this issue please include below under VRF I9003:Mgmt
Hope this helps to solve your issue. Please let me know for any more clarifications.
Varma
12-08-2011 11:58 PM
Thanks for your quick reply Varma.
I disagree. Actually I noticed that the successful export map entry is local static route being redistributed into bgp. Then I went to another PE router which has many inter-VRF leaks configured. I've seen that router does export some EBGP route prefixes from one VRF to the other. ( I Very carefully verified via ' sh ip bgp vpnv4 vrf x.x.x.x' on that router against the specific export prefixes. )
Another Fact which had made me a heart attack, I also tried import all Rt 17669:1010 into I9003:Mgmt. This action made the entire remote DC down for 10mins, until i hopped on a terminal server and deleted the import all 178669:1010. fortunately it's not a production site. Otherwise I am screwed.
Any other idea?
Robo
12-09-2011 12:10 AM
Hi Robo
I agree that the successful export map entry is the one which is locally present and we can apply outbound communities to locally exported routes only and the same was my reasoning above that it will work for local routes only.
As mentioned above the unsuccsessful export map entry is the one for the external EBGP route learnt across MPLS VPN Cloud as we are importing that route onto the local MPLS-PE and and not re-exporting it and hence the export map does not apply to it.
I do not see any reason for the import of RT Rt 17669:1010 into the VRF I9003:Mgmt not working when same is working for VRF V1010:LLL
Can you please proivde the relevant configuration and show outputs on another working PE which has the same configuration as used on this local PE under question ?
Varma
12-09-2011 01:10 AM
I don't mean the route import wasn't successful. It was so successful that it messed around the Mgmt VRF routing table ( I could see all those foreign LLL routes appearing when I consoled access to it).
I indeed have the entire config for the other router tonight after dinner with family. But I may not be able to give you some stats other than config itself (it's my last day in the company). Bet you can tell if the export prefixes are outside or local.
Thanks again Mr. Varma
12-09-2011 03:39 AM
Hi Varma, I just uploaded the config of the other router. Please see the enclosed file "SYD MPLS Edge#1.txt".
You may see there are a few export maps exporting non local IGP routes.
e.g.
ip vrf I9003:Mgmt
rd 17669:900301
export map I9003:Ipx-International-to-LH
under that export router map, the there are 3 prefixes are selected-
10.5.16.0/24; 10.6.16.0/24;10.3.16.0/24
none of them is local IGP routes
I had "show ip bgp vpnv4 vrf I9003:Mgmt 10.5.16.0" this morning (or maybe another prefix in these 3), the AS numbers appending it are more than 5. Sorry I can't give you exact stats. But I am 100% sure I saw more than 5 ASN attach to it. That's why I confirmed "only local routes can be exported or leaked" isn't correct.
Let me know what you think
Thanks!
Robo
12-09-2011 02:34 PM
I just reviewed the whole config again on the problemed router and found that router is configed as VRF-Lite rather than MP-BGP... it doesn't have address family vpnv4 configured to point back to MPLS core... the name convention of device itself fooled me (xxxMPLSxxx)...
If it is the case, might be better to create another new VRF to collect the prefixes which I wish them to talk to each other.
here might be the solution.
http://www.netcraftsmen.net/resources/blogs/using-bgp-with-vrf-lite-for-shared-service-support.html
What do you think? (I didn't sleep well last night and trying to find a solution even in dream...)
12-09-2011 07:06 PM
Hi Robo
Sorry got held up yesterday with work so could not reply timely..
I did take a look at the link provided and it also mentions the same logic of only exporting local routes on the Local PE ( MPLS PE or VRF-Lite does not matters as a fact). The point here I am making is that if we receive and external route then we can not re-export it to other VRFs which are locally configured or as a matter of fact back to the backbone. This is what is the issue here for the prefix 10.130.100.0 not being imported into VRF I9003:Mgmt.
Now one solution was to directly import this external route into the VRF using Import RT but you have mentioned that it caused unwanted routing updates..We can try an import-map there to control the desired prefix but not sure if this scales for your topology.
The option to create a separate VRF and directly import the route using import RT has the same issue as above for receiving unwanted routing updates..So I would suggest to use import-map under the existing VRF and import the required RT 17669:1010 with other desired prefixes.
Hope this helps to answer your question.
Varma
12-09-2011 11:55 PM
Thanks Varma, I am trying to find the document online to quote on what you explained. No solid result returns back saying PE can not export external routes but can export local only. Could you show me some Cisco docs?
Don't know if you have verified the 2nd config file I uploaded called 'SYD MPLS EDGE#1' on the original post. Some export map literally export the ebgp prefixes with no joke.(Plz see what i pointed at the post 4:41am 9th Dec)
So many thanks for your time Varma. I hope I can understand it really soon after your great helps. :)
Robo
12-10-2011 01:23 AM
Hi Robo
I did look at your latest files and it has only running config and no show outputs which would illustrate re-exporting an external route which is learnt across BGP.
But actually now I understand there is a difference in what context I was saying no re-export of external BGP routes and whats the setup here . I was thinking on the grounds of the iBGP split horizon rule for not re-exporting any iBGP routes to another iBGP peer but that does not holds good here..
So coming back to this issue of an eBGP route being learnt in one VRF and not exported to another VRF on same PE based on the addtional RT value this is quite strange . The issue which is seen looking at the logs attached in your first post I can see that the additive RT value of 17669:101011 is not being applied to the route 10.130.100.0 and missing which is obstructing the import of this route to I9003:Mgmt VRF.Not sure why at this moment but am still thinking for it.
Extended Community: RT:17669:1010 "Additive Community Missing Here"
Varma
12-10-2011 04:01 AM
welcome back Vaibhava? how u been long time no see Hope you well
12-10-2011 04:04 AM
Hey Kishore
Yes quite busy in the last few days Hey what do you think might be happening on this issue if you got time to go through it
Varma
12-10-2011 05:41 PM
Hey Varma,
Nice to hear from you. In regards to the export map , AFAIK the prefix doesn't have to be to be local to the router. As long as its in the vrf RIB you can muck around with it. Please see below
R1#sh ip bgp vpnv4 vrf B 50.50.50.50
BGP routing table entry for 200:1:50.50.50.50/32, version 26
Flag: 0x820
Local
20.1.1.2 from 0.0.0.0 (1.1.1.1)
Origin incomplete, metric 1, localpref 100, weight 32768, valid, sourced, best
mpls labels in/out 20/nolabel
R1#sh ip route vrf B 50.50.50.50
Routing entry for 50.50.50.50/32
Known via "rip", distance 120, metric 1
Redistributing via bgp 6500, rip
Advertised by bgp 6500
Last update from 20.1.1.2 on GigabitEthernet2/0.20, 00:00:20 ago
Routing Descriptor Blocks:
* 20.1.1.2, from 20.1.1.2, 00:00:20 ago, via GigabitEthernet2/0.20
Route metric is 1, traffic share count is 1
R1#sh route-map
Match clauses:
ip address (access-lists): 10 20
Set clauses:
10 permit 22.22.22.22 (11 matches)
Standard IP access list 20
10 permit 50.50.50.50 (3 matches)
R1#sh run | be vrf
ip vrf A
rd 100:1
ip vrf B
rd 200:1
export map B-to-A
Kishore
12-10-2011 05:20 AM
Mr. V.
That's exact what I have been confused by...
if I have a change to touch that router again, I would do the following to exchange RT between VRFs.
1. create a new VRF AAA
2. Import 17669:1010 and 17669:9003 into it
3. export map match 10.130.100.0/24 and set a new RT 17669:xxxx "without additive";
and match 10.8.0.0/24 then set a new RT 17669:yyyy "without additive" too
5. go to VRF Mgmt and import new RT 17669:xxxx and go to VRF LLL and import RT 17669:yyyy
This should eliminate the issue of 2nd additive extended RT can't not be attched. I hope.
Do you agree Mr. V?
Heaps thanks so far mate, your very helpful and knowledgable.
Robo
