Warning message
setting up RDP on Cisco 861 HELP !
Dec 9th, 2011
Before I installed the Cisco 861 I used a simple Linksys router and RDP worked just fine. I just forwarded port 3389 to the servers IP 192.168.0.1 and everything worked, I could log in into the server.
Now I'm trying to set up RDP on a Cisco 861, but..... not working......
My router got a fixed ip though the ISP. Can someone please give me some help ? Thanks in advance !
My routerconfig:
Building configuration...
Current configuration : 9282 bytes
! Last configuration change at 07:25:33 PCTime Tue Jan 3 2006 by DVMAdmin
! NVRAM config last updated at 07:25:33 PCTime Tue Jan 3 2006 by DVMAdmin
version 15.0
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname administratie01
boot-start-marker
boot-end-marker
logging buffered 51200
logging console critical
enable secret 5 $1$IqhW$06dr6Y2q7cscIOR5bUsWr1
no aaa new-model
memory-size iomem 10
clock timezone PCTime 1
clock summer-time PCTime date Mar 30 2003 2:00 Oct 26 2003 3:00
crypto pki trustpoint TP-self-signed-635537874
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-635537874
revocation-check none
rsakeypair TP-self-signed-635537874
crypto pki certificate chain TP-self-signed-635537874
certificate self-signed 01
  30820254 308201BD A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 36333535 33373837 34301E17 0D303630 31303231 32303034
  345A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
  532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3633 35353337
  38373430 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
  D77176FC D35ED86B 20C86E2E 46003C34 58DDA68D 26D4FEC4 73DAE739 D7BF6E0C
  CF06D14B F1B6664B 67CDE7FD C5EDB66E BBC0184E B96A3A8D 8C8E8BF1 64D6FC61
  961E32D4 42A93E69 A8DEA22E C89E34E5 EFAB44F3 359EC235 96E670B1 CB0B5695
  014FE5D8 FE2740A6 396B9FD7 BB69F048 BA3AEC80 1E74157F 34060078 13D97613
  02030100 01A37E30 7C300F06 03551D13 0101FF04 05300301 01FF3029 0603551D
  11042230 20821E61 646D696E 69737472 61746965 30312E79 6F757264 6F6D6169
  6E2E636F 6D301F06 03551D23 04183016 8014FD97 79FA75CB 647A32B3 0DEFCA16
  07328239 D2ED301D 0603551D 0E041604 14FD9779 FA75CB64 7A32B30D EFCA1607
  328239D2 ED300D06 092A8648 86F70D01 01040500 03818100 46B40985 B9DD44D6
  E83F36F9 6AE91FE4 C2BB5662 4E965E8D 396FC35D F574A71A 88453EC4 201F92CF
  6B177CCC 14E24123 97B16215 6E9CC0A3 76A96360 71C68937 3DA57479 D9F3BB52
  905DE3DB 1BC5C933 D6D089C3 9C592636 A69AF443 34F00B47 77DC58CE C2B7B0E3
  8D02D164 3D4807AE 0B567FF6 849EE77F 28113565 077587DB
            quit
no ip source-route
ip cef
no ip bootp server
no ip domain lookup
ip domain name yourdomain.com
license udi pid CISCO861-K9 sn FCZ1533C0NT
object-group service RDP
description RDP
tcp-udp eq 3389
tcp-udp source eq 3389
object-group service REMOTE_DESKTOP
tcp eq 3389
tcp source eq 3389
username DVMAdmin privilege 15 secret 5 $1$NLY2$LhTwKyL5zJ8qhDdGPgnzr0
username admin privilege 15 view root secret 5 $1$DWOC$Q3HI0KDRTd547WqCCIm4o0
ip tcp synwait-time 10
ip ssh time-out 60
ip ssh authentication-retries 2
class-map type inspect match-any SDM_BOOTPC
match access-group name SDM_BOOTPC
class-map type inspect match-any SDM_HTTPS
match access-group name SDM_HTTPS
class-map type inspect match-any SDM_SSH
match access-group name SDM_SSH
class-map type inspect match-any SDM_SHELL
match access-group name SDM_SHELL
class-map type inspect match-any sdm-cls-access
match class-map SDM_HTTPS
match class-map SDM_SSH
match class-map SDM_SHELL
class-map type inspect match-any SDM_DHCP_CLIENT_PT
match class-map SDM_BOOTPC
class-map type inspect match-any ccp-skinny-inspect
match protocol skinny
class-map type inspect match-any sdm-cls-bootps
match protocol bootps
class-map type inspect match-any ccp-cls-insp-traffic
match protocol cuseeme
match protocol dns
match protocol ftp
match protocol https
match protocol icmp
match protocol imap
match protocol pop3
match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
class-map type inspect match-all ccp-insp-traffic
match class-map ccp-cls-insp-traffic
class-map type inspect match-any ccp-h323nxg-inspect
match protocol h323-nxg
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-any ccp-h225ras-inspect
match protocol h225ras
class-map type inspect match-any ccp-h323annexe-inspect
match protocol h323-annexe
class-map type inspect match-all sdm-access
match class-map sdm-cls-access
match access-group 101
class-map type inspect match-any ccp-h323-inspect
match protocol h323
class-map type inspect match-all ccp-icmp-access
match class-map ccp-cls-icmp-access
class-map type inspect match-all ccp-invalid-src
match access-group 100
class-map type inspect match-any ccp-sip-inspect
match protocol sip
class-map type inspect match-all ccp-protocol-http
match protocol http
policy-map type inspect ccp-permit-icmpreply
class type inspect sdm-cls-bootps
  pass
class type inspect ccp-icmp-access
  inspect
class class-default
  pass
policy-map type inspect ccp-inspect
class type inspect ccp-invalid-src
  drop log
class type inspect ccp-protocol-http
  inspect
class type inspect ccp-insp-traffic
  inspect
class type inspect ccp-sip-inspect
  inspect
class type inspect ccp-h323-inspect
  inspect
class type inspect ccp-h323annexe-inspect
  inspect
class type inspect ccp-h225ras-inspect
  inspect
class type inspect ccp-h323nxg-inspect
  inspect
class type inspect ccp-skinny-inspect
  inspect
class type inspect sdm-access
  inspect
class type inspect SDM_DHCP_CLIENT_PT
  pass
class class-default
  drop
zone security out-zone
zone security in-zone
zone-pair security ccp-zp-self-out source self destination out-zone
service-policy type inspect ccp-permit-icmpreply
zone-pair security ccp-zp-in-out source in-zone destination out-zone
service-policy type inspect ccp-inspect
zone-pair security ccp-zp-out-self source out-zone destination self
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description $ES_WAN$$FW_OUTSIDE$
ip address dhcp client-id FastEthernet4
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
ip virtual-reassembly
zone-member security out-zone
duplex auto
speed auto
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
ip address 192.168.0.10 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
zone-member security in-zone
ip tcp adjust-mss 1452
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface FastEthernet4 overload
ip nat inside source static tcp 192.168.0.1 3389 interface FastEthernet4 3389
ip access-list extended RDP
remark CCP_ACL Category=1
permit object-group RDP any host 192.168.0.1
ip access-list extended REMOTE_DESKTOP
permit object-group REMOTE_DESKTOP any host 192.168.0.1
ip access-list extended SDM_BOOTPC
remark CCP_ACL Category=0
permit udp any any eq bootpc
ip access-list extended SDM_HTTPS
permit tcp any any eq 443
ip access-list extended SDM_SHELL
permit tcp any any eq cmd
ip access-list extended SDM_SSH
permit tcp any any eq 22
logging trap debugging
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.0.0 0.0.0.255
access-list 100 remark CCP_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
access-list 101 remark CCP_ACL Category=128
access-list 101 permit ip any any
no cdp run
control-plane
banner exec ^C
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for  one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username <myuser> privilege 15 secret 0 <mypassword>
Replace <myuser> and <mypassword> with the username and password you
want to use.
^C
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
no modem enable
transport output telnet
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
cadet alain Sat, 12/10/2011 - 10:34
  • Purple, 4500 points or more
this is due to your ZBF config, you must configure a policy from out to in that inspects RDP:
ip inspect log drop-pkt
permit tcp any host 192.168.0.1 eq 3389
permit udp any host 192.168.0.1 eq 3389
class-map type inspect RDP_TRAFFIC
match access-group name RDP
policy-map type inspect RDP_POLICY
class type inspect RDP_TRAFFIC
  inspect
zone-pair security RDP_OUT_IN source out-zone destination in-zone
service-policy type inspect RDP_POLICY
Regards.
Alain
