Support of ACL on cisco 7600
Dec 9th, 2011
I would like to know the IOS which supports :ACL Support for Filtering on TTL Value feature on my Cisco 7600 device.
I check on cisco and found the Cisco 12.4T release but this software doesnt fit onto my chasis.
Checked on the following links:
https://docs.google.com/viewer?a=v&q=cache:AssXuC-ynAIJ:www.cisco.com/en/US/docs/ios/sec_data_plane/configuration/guide/sec_accs_list_rmap.pdf+IOS+supports+ACL+Support+for+Filtering+on+TTL+Value&hl=en&gl=in&pid=bl&srcid=ADGEESiZHw5tEP1Gz3XGV93ESSLldxkZH4WKQD0H6pLzS1eRoWhXeXCsuRMGE0EpVJ6p-Dp8uqlCgHdT3J7ikL7ieHBdAzfUTaZqWP3YJ7FtRFIpmR4k9t9wlEZKCEhLrI60SeVZNnsc&sig=AHIEtbSV7kq5X_XYQDktdHYScMqxSSpFXw
2)
Cisco feature navigator:
http://tools.cisco.com/ITDIT/CFN/jsp/by-feature.jsp
But got no luck.
I would appriciate if someone can guide me to which software should I  upgrade to on my cisco 7600 to have this feature would be highly  appriciated.
Thanks in advance.
REgards
Fariha
Reza Sharifi Fri, 12/09/2011 - 16:34
  • Cisco Designated VIP,
    2017 LAN
Fariha,
What do you mean when you say "but this software doesnt fit onto my chasis"?
You don't have enough space in your flash?
fariha zain Fri, 12/09/2011 - 16:55
Reza,
I meant was that this software for Cisco 7600 device?
Could you please help me with the version which has this feature to be installed on cisco 7600/6500?
REgards
FAri
Reza Sharifi Fri, 12/09/2011 - 17:33
    2017 LAN
Fari,
I don't have a device to test this but according the command reference guide for the 6500, ttl in one of the options:
ttl operator value
(Optional) Compares the TTL value in the packet to the TTL value specified in this permit statement.
The operator can be lt (less than), gt (greater than), eq (equal), neq (not equal), or range (inclusive range).
The value can range from 0 to 255.
If the operator is range, specify two values separated by a space.
For Release 12.0S, if the operator is eq or neq, only one TTL value can be specified.
For all other releases, if the operator is eq or neq, as many as 10 TTL values can be specified, separated by a space.
here is the link
http://www.cisco.com/en/US/docs/ios/security/command/reference/sec_p1.html#wp1089342
