Warning message
UC560 - Blast Group - No Answer Forward
Dec 10th, 2011
Hello Everyone.  I have a question on blast groups in a multisite environment with the 8.2  software pack.
In this environment, a call come into Site B and is routed intersite to a blast group in Site A.  This works - all phones ring as expected.  The blast group has a "no answer forward" destination of "other" set to an AA back in Site B.  This is not working.  The blast group just rings and rings and rings.
Can anybody help?
David Trad Sat, 12/10/2011 - 15:41
  • Gold, 750 points or more
  • Cisco Designated VIP,
    2013 Small Business
Hi John,
You need to check and see if Site-A has a Dial-Peer that references back to Site-B's AA.
You may also need to capture a Dial-Peer debug for us to see what is going on, but your scenario should work so long as there is a call routing path to the destination and the site can reach the other end.
Actually one way to test this, is to see if you can call Site-B's AA from Site "A" just by dialing it.
Cheers,
David.
