Site to Site with RVS4000 and 2621
Answered Question
Dec 10th, 2011
Hey people. I originally had a site to site vpn between my pix 515e and RVS4000, but wanted to put my router on the edge of my network for greater QOS control. I've managed to get the tunnel up, but can't get any traffic across the tunnel. The RVS4000 says the tunnel is up, and when I do a "show crypto isakmp sa" on the 2621, I see a QM_IDLE which I believe it good.
My architecture is this:
LAN - RVS4000 (static public ip) ----internet------2621(dynamic public IP ((dhcp)) - LAN
Below is a copy of my 2621 config. My guess is I left something out, but can't put my finger on it. Any help is appreciated. Thanks!
version 12.3
service password-encryption
hostname core_router
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip cef
ip domain name craig.net
         ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip multicast-routing
ip audit po max-events 100
voice service voip
fax protocol pass-through g711ulaw
h323
sip
username craigrobertlee privilege 15 password 7 XXXXXXXXXXX
--More--                           !
ip ssh time-out 60
ip ssh source-interface FastEthernet0/1
ip ssh rsa keypair-name craigkey
class-map match-any VOIP_TRAFFIC
  match access-group 101
policy-map VOIP_POLICY
  class VOIP_TRAFFIC
   bandwidth 1000
  class class-default
   fair-queue
crypto isakmp policy 10
encr 3des
hash md5
authentication pre-share
group 2
         crypto isakmp key XXXXXXXX address 174.79.X.X no-xauth
crypto isakmp keepalive 2800
crypto ipsec transform-set SET1 esp-3des esp-md5-hmac
crypto map ROGERS 10 ipsec-isakmp
set peer 174.79.X.X
set security-association idle-time 60
set transform-set SET1
match address 102
interface Null0
no ip unreachables
interface FastEthernet0/0
ip address dhcp
ip nat outside
speed 100
full-duplex
crypto map ROGERS
service-policy output VOIP_POLICY
ip address 192.168.0.1 255.255.255.252
ip nat inside
duplex auto
speed auto
interface Dialer1
no ip address
no cdp enable
ip nat inside source list 100 interface FastEthernet0/0 overload
no ip http server
no ip http secure-server
ip classless
ip route 192.168.1.0 255.255.255.0 192.168.0.2
ip route 192.168.2.0 255.255.255.0 192.168.0.2
ip route 192.168.3.0 255.255.255.0 192.168.0.2
access-list 10 permit 192.168.1.254
         access-list 11 permit 192.168.1.10
access-list 12 permit 192.168.0.0 0.0.255.255
access-list 12 remark SSH_ACL
access-list 100 permit ip 192.168.0.0 0.0.255.255 any
access-list 100 remark Craig_Home_IP_Network
access-list 101 permit udp any eq 5060 any eq 5060
access-list 101 remark VOIP_ACL
access-list 102 permit ip 192.168.0.0 0.0.3.255 192.168.15.0 0.0.0.255
access-list 102 remark ROGERS_IP_NETWORK
access-list 110 deny   ip 192.168.0.0 0.0.3.255 192.168.15.0 0.0.0.255
access-list 110 permit ip 192.168.0.0 0.0.3.255 any
no cdp run
route-map nonat permit 10
match ip address 110
snmp-server community craighome1 RO 11
snmp-server location Gear Closet
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps tty
snmp-server enable traps xgcp
snmp-server enable traps isdn call-information
snmp-server enable traps isdn layer2
--More--                           snmp-server enable traps isdn chan-not-avail
snmp-server enable traps isdn ietf
snmp-server enable traps hsrp
snmp-server enable traps config
snmp-server enable traps entity
snmp-server enable traps config-copy
snmp-server enable traps envmon
snmp-server enable traps bgp
snmp-server enable traps pim neighbor-change rp-mapping-change invalid-pim-message
snmp-server enable traps ipmulticast
snmp-server enable traps msdp
snmp-server enable traps rsvp
snmp-server enable traps frame-relay
snmp-server enable traps frame-relay subif
snmp-server enable traps rtr
snmp-server enable traps syslog
snmp-server enable traps stun
snmp-server enable traps dlsw
snmp-server enable traps bstun
snmp-server enable traps dial
snmp-server enable traps dsp card-status
snmp-server enable traps atm subif
--More--                           snmp-server enable traps pppoe
snmp-server enable traps ipmobile
snmp-server enable traps isakmp policy add
snmp-server enable traps isakmp policy delete
snmp-server enable traps isakmp tunnel start
snmp-server enable traps isakmp tunnel stop
snmp-server enable traps ipsec cryptomap add
snmp-server enable traps ipsec cryptomap delete
snmp-server enable traps ipsec cryptomap attach
snmp-server enable traps ipsec cryptomap detach
snmp-server enable traps ipsec tunnel start
snmp-server enable traps ipsec tunnel stop
snmp-server enable traps ipsec too-many-sas
snmp-server enable traps voice poor-qov
snmp-server enable traps dnis
snmp-server host 192.168.1.10 version 2c craighome1
line con 0
login local
--More--                           line aux 0
line vty 0 4
access-class 12 in
exec-timeout 0 0
login local
transport input ssh
line vty 5 15
access-class 12 in
exec-timeout 0 0
login local
transport input ssh
ntp clock-period 17180394
ntp server 192.43.244.18
end
Correct Answer by raga.fusionet about 5 years 8 months ago
Perhaps you are running a version that doesnt have that command?
I do have it :
R4(config)#crypto isakmp client configuration group vpnclient
R4(config-isakmp-group)#?
ISAKMP group policy config commands:
  access-restrict               Restrict clients in this group to an interface
  acl                           Specify split tunneling inclusion access-list
                                number
  auto-update                   Configure auto-upgrade
  backup-gateway                Specify backup gateway
  banner                        Specify mode config banner
  browser-proxy                 Configure browser-proxy
  configuration                 Push configuration to the client
  crypto                        Client group crypto aaa attribute list
  dhcp                          Configure DHCP parameters
  dns                           Specify DNS Addresses
  domain                        Set default domain name to send to client
  exit                          Exit from ISAKMP client group policy
                                configuration mode
  firewall                      Enforce group firewall feature
  group-lock                    Enforce group lock feature
  include-local-lan             Enable Local LAN Access with no split tunnel
  key                           pre-shared key/IKE password
  max-logins                    Set maximum simultaneous logins for users in
                                this group
  max-users                     Set maximum number of users for this group
  netmask                       netmask used by the client for local
                                connectivity
  no                            Negate a command or set its defaults
  pfs                           The client should propose PFS
  pool                          Set name of address pool
  save-password                 Allows remote client to save XAUTH password
  smartcard-removal-disconnect  Enables smartcard-removal-disconnect
  split-dns                     DNS name to append for resolution
  wins                          Specify WINS Addresses
R4(config-isakmp-group)# split-dns atw.local
R4(config-isakmp-group)#end
R4#
*Mar  1 00:15:44.567: %SYS-5-CONFIG_I: Configured from console by console
R4#sh ver
Cisco IOS Software, 2600 Software (C2691-ADVENTERPRISEK9-M), Version 12.4(15)T14, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Tue 17-Aug-10 07:38 by prod_rel_team
ROM: ROMMON Emulation Microcode
ROM: 2600 Software (C2691-ADVENTERPRISEK9-M), Version 12.4(15)T14, RELEASE SOFTWARE (fc2)
R4 uptime is 15 minutes
System returned to ROM by unknown reload cause - suspect boot_data[BOOT_COUNT] 0x0, BOOT_COUNT 0, BOOTDATA 19
System image file is "tftp://255.255.255.255/unknown"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 2691 (R7000) processor (revision 0.1) with 249856K/12288K bytes of memory.
Processor board ID XXXXXXXXXXX
R7000 CPU at 160MHz, Implementation 39, Rev 2.1, 256KB L2, 512KB L3 Cache
2 FastEthernet interfaces
3 Serial(sync/async) interfaces
DRAM configuration is 64 bits wide with parity enabled.
55K bytes of NVRAM.
16384K bytes of ATA System CompactFlash (Read/Write)
Now, to test if you are indeed having a split DNS problem remove the ACL for split tunneling ACL
no acl 177
Then try to resolve local names. If it works then you might need to upgrade your IOS so that you can have the split dns functionality.
Sure, I listed the steps a few days ago for a couple of friends:
Enable AAA:
aaa new-model
aaa authentication login userauthen local
aaa authorization network groupauthor local
Create an isakmp Policy:
crypto isakmp policy 3
encr 3des
group 2
create an IP pool:
ip local pool ippool 192.168.100.10 192.168.100.20
Create the split tunneling ACL (Allows the user to browse the Internet while connected with the VPN)
access-list 177 permit ip 192.168.0.0 0.0.0.255 192.168.100.0 0.0.0.255
Create a VPN group:
crypto isakmp client configuration group VPN3000
key cisco123
domain cisco.com
pool ippool
acl 177
Create an IPSec Policy:
crypto ipsec transform-set 3des-sha esp-3des esp-sha-hmac
Create a Dynamic crypto map and set the transform set.
crypto dynamic-map dynmap 10
set transform-set 3des-sha
Create a crypto map, link the AAA and the dynamic crypto map
crypto map ROGERS client authentication list userauthen
crypto map ROGERS isakmp authorization list groupauthor
crypto map ROGERS client configuration address respond
crypto map ROGERS 1000 ipsec-isakmp dynamic dynmap
Add a NAT excemption for the VPN traffic:
access-list 110 deny   ip 192.168.0.0 0.0.3.255 192.168.100.0 0.0.0.255 (This line must go before the "permit")
And that should do it.
Have a good one.
Hi Robert,
You are using ACL 100 for NAT when you should be using either ACL 110 or the route map nonat, it looks like you meant to bypass NAT but forgot to apply it.
This is what you have:
This is what you should have instead:
ip nat inside source list 110 interface FastEthernet0/0 overload
or
ip nat inside source route-map nonat interface FastEthernet0/0 overload
Have fun,
Raga
Overall Rating: 5 (3 ratings)
Correct Answer
raga.fusionet Sun, 12/11/2011 - 16:54
  • Silver, 250 points or more
Hi Robert,
or
Have fun,
Raga
Robert Craig Sun, 12/11/2011 - 17:32
Thats exactly what it was. It dawned on me this morning that the two statements weren't actually doing anything. Now, with the current config, can you give me an example of also allowing VPN Clients (Cisco VPN Client) to connect? Thanks!
Correct Answer
raga.fusionet Sun, 12/11/2011 - 17:55
Enable AAA:
aaa new-model
encr 3des
group 2
create an IP pool:
Create a VPN group:
key cisco123
domain cisco.com
pool ippool
acl 177
Have a good one.
Robert Craig Mon, 12/12/2011 - 12:40
OK, I got the client to connect, and was able to browse. However, the client receives the DNS server that it is supposed to use, yet when you do an nslookup or perform any DNS resolutions, it uses the DNS server handed out by it's local router and not the one my router is sending the client. Below is the config. Is this normal?
key XXXXX
dns 192.168.1.252
domain atw.local
pool VPN_Client
acl 177
raga.fusionet Mon, 12/12/2011 - 12:46
Robert,
Try adding this under the VPN client gruop configuration:
split-dns atw.local
Robert Craig Mon, 12/12/2011 - 12:48
If you are talking about adding it to the "crypto isakmp client configuration group vpnclient", that command isn't even available.
Correct Answer
raga.fusionet Tue, 12/13/2011 - 05:38
I do have it :
                                number
                                configuration mode
                                this group
                                connectivity
R4#
R4#sh ver
[email protected].
55K bytes of NVRAM.
no acl 177
Robert Craig Tue, 12/13/2011 - 08:12
Aha, there is the culprit. I am running a 2621 (non XM version) which does not support 12.4. I am stuck at 12.3(26) as my highest. But, thats ok. I also figured out that the local network the client is coming from is on 192.168.1.0 which also resides on my side of the house. So, that network is never being put into the clients routing table because he/she already has it. I am either going to move some of my stuff away from that network or have the client move his. I never really paid attention to the helpful hints to avoid using the common private network spaces in my own because this sort of event would happen until now. But, do I choose a higher Class C, B? One wonders.....
Related Content
