Warning message
How to list Ciscoworks patches that installed on server
Dec 11th, 2011
We have LMS3.2,CS3.3 and RME 4.3.1 on solaris 9 and I want to know what were cisco patches installed on the server in order to install other patches without any problem.
Marvin Rhoads Sun, 12/11/2011 - 08:40
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 Firewalling, Network Management, VPN
If you are looking to just make your LMS current, the update feature tht's built into CiscoWorks will do that for you. If you're looking for offline verification to download and install patches / updates manually, there's an install.log created whenever an update is performed. It's parsed nicely for you if you just go to the GUI (Reference) by selecting Common Services > Software Center > Software Update.
There is also a compilation of the various CiscoWorks applications and version in this document. It is more recent than the FAQ link posted above.
Hope this helps.
