Management access (ASDM/console) to FWSM through the outside interface (Sec level 0)
Jul 13th, 2011
What am I not able to have admin access (ASDM/console) on FWSM through the outside interface (Sec level 0)
Anu M Chacko Wed, 07/13/2011 - 00:04
  • Cisco Employee,
Is the FWSM in multiple context? Have you allowed your network to have asdm access to the outside? Could you post the "sh run" here?
Anu
Siju S Wed, 07/13/2011 - 00:35
Its not in multi-context
Access has been enabled , but still iam not able to connect from outside interface or routed vlan's, however iam able to access from all inside interfaces (higher sec level)
http server enable
http 10.0.X.0 255.255.255.0 outside
management-access outside
asdm location 10.0.x.x 255.255.255.255 outside
Anu M Chacko Wed, 07/13/2011 - 00:43
  • Cisco Employee,
Hi Kauser,
The IP you're using is a Private IP. i would expect to see a public IP subnet in those commands, since you're trying to connect to the outside interface from an outside network.
Hope this helps!
Anu
Siju S Wed, 07/13/2011 - 06:47
The outside and inside interfaces  are virtual interfces separating priviate vlans in a core switch hosting  servers.
.Basically iam not able to get admin access from  security level 0 interface .I need to find out whether there is any way  to achieve this
varrao Wed, 07/13/2011 - 00:04
  • Red, 2250 points or more
Hi Kausar,
Can you provide the configuration that you ahve done for admin access on outside along with the running-config.
Varun
varrao Wed, 07/13/2011 - 00:41
Hi Kauser,
The location from you are testing needs to be connected to the outside interface, I am not sure, but it seems that you are trying to connect from a PC which is on the inside interface,  you would not be able to access the ASDM from a remote interface. You can ASDM into the firewall from internet, for which the request would fall on the outside interface, in your case i guess the request is coming on the inside interface, for ASDM on outside, which is not correct.
Varun
Siju S Wed, 07/13/2011 - 06:39
Anu M Chacko Thu, 07/14/2011 - 00:30
  • Cisco Employee,
Hi Kauser,
Could you post the output of "show run int" from the FWSM here? Also, is the FWSM running in multiple context?
Anu
Siju S Thu, 07/14/2011 - 02:14
Firewall/6# sh run int
interface Vlan5
nameif DMZ5
security-level 50
ip address 10.X.X.X 255.255.255.0
interface Vlan6
nameif DMZ6
security-level 50
interface Vlan7
nameif DMZ7
security-level 50
interface Vlan100
nameif outside
security-level 0
ip address 10.X.X.X 255.255.255.252
interface Vlan101
description LAN Failover Interface
interface Vlan102
nameif inside
security-level 100
Anu M Chacko Thu, 07/14/2011 - 03:59
  • Cisco Employee,
Hi Kauser,
Is NAT enabled on the firewall? How does the world see the outside IP? What is the next hop for this firewall(def route)? It would be great if you can post the output of "sh run" here.
Anu
Siju S Sun, 07/17/2011 - 05:01
Dear,
This is an FWSm module with default route to Core Sw MSFC , the outside IP can be reached from any access vlan in core sw
Anu M Chacko Mon, 07/18/2011 - 00:43
  • Cisco Employee,
Hi Kauser,
What is the IP address of the host from where you're trying to reach the FWSM outside interface? Give me an eg.
Anu
Siju S Sun, 12/11/2011 - 06:16
Anybody experiencing the same difficult , is there any workaround ?
Julio Carvajal Sun, 12/11/2011 - 13:07
  • Purple, 4500 points or more
Hello Kausar,
First of all lets take out all the ASDM configuration ( just in case the ASDM daemon got stuck)
no  http server enable
no http 10.0.X.0 255.255.255.0 outside
Now can you add the following command just to test the connection?
http server enable
http 0 0 outside
If this do not work,I would like to see the debug for the http protocol
Debug http
Please provide the output of the debug.
Please rate helpful posts!!
Julio
Siju S Wed, 12/14/2011 - 20:15
HI Julio,
Iam able to open asdm from all the security vlans , except from outside .
Julio Carvajal Wed, 12/14/2011 - 20:57
Hello Kausar,
Thanks for the info, I read that on the previous posts.
Can you provide the information I request??
Julio
Related Content
