is it possible to have 2 RA VPNs on a ASA5505
Answered Question
Dec 12th, 2011
Hi there,
I am looking into setting up 2 remote access VPNs; one will have split tunnelling and the other won’t have split tunnelling configured other than that both are identical.
Below is the config I’m planning to use:
ASA Version 8.3(1)
ip local pool VPNPOOL 192.168.20.1-192.168.20.254
object network obj-vpnpool
subnet 192.168.XX.0 255.255.255.0
object network net_internal
subnet 10.0.XX.0 255.255.255.0
nat (inside,any) source static net_internal net_internal destination static obj-vpnpool obj-vpnpool
access-list ravpn_ex extended permit ip 10.0.XX.0 255.255.255.0 192.168.XX.0 255.255.255.0 log
access-list ravpn_ex extended permit icmp 10.0.XX.0 255.255.255.0 192.168.XX.0 255.255.255.0 log
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
crypto ipsec transform-set RA-TS esp-3des esp-sha-hmac
crypto dynamic-map DYN_MAP 10 set transform-set RA-TS
crypto map VPN_MAP 65535 ipsec-isakmp dynamic DYN_MAP
crypto map VPN_MAP interface outside
crypto isakmp enable outside
group-policy RA01-vpn internal
group-policy RA01-vpn attributes
dns-server value XX.XX.XX.XX XX.XX.XX.XX
vpn-idle-timeout 60
split-tunnel-policy tunnelspecified
split-tunnel-network-list value ravpn_ex
tunnel-group RA01 type remote-access
tunnel-group RA01 general-attributes
address-pool VPNPOOL
default-group-policy RA01-vpn
tunnel-group RA01 ipsec-attributes
pre-shared-key *****
TUNNEL TWO:
group-policy RA02-vpn internal
group-policy RA02-vpn attributes
vpn-idle-timeout 60
tunnel-group RA02 type remote-access
tunnel-group RA02 general-attributes
default-group-policy RA02-vpn
tunnel-group RA02 ipsec-attributes
Can anyone confirm if this will work or if there is another way I can achieve the same outcome?
Dale
Correct Answer by Keith McElroy about 5 years 6 months ago
It is absolutely possible. Right now I do this on an ASA 5540 with 4 different RA groups for different departments.
Overall Rating: 5 (1 ratings)
yiuyuenyan Mon, 12/12/2011 - 07:32
Hi there,
can you tell me which one vpn have split tunnelling and other wont' have split tunnelling ?
Correct Answer
Keith McElroy Wed, 12/14/2011 - 11:54
