Warning message
Cisco ACE appliance backend Requests
Dec 12th, 2011
I have a question about the Cisco ACE 4700x  appliances.
I hope that someone can help me out with the next question please, which is:
does the appliance support backend server selection based on URL, hostnames or IP?
if yes, where can i find more details about it ?
Thank you
Surya ARBY Mon, 12/12/2011 - 11:47
  • Silver, 250 points or more
no problem. it will be done with class-maps based on source ip address, URL or HTTP header (Host field in your case)
doubstar1 Tue, 12/13/2011 - 00:37
Thank you so mutch surya.
do you have examples guidelines, documentation on this matter please ?
Kind regards,
Said
Surya ARBY Tue, 12/13/2011 - 02:56
Here it is.
class-map type http loadbalance match-all DOMAIN-ONLY-CM
  2 match http header Host header-value "xxx[.]domain[.]com"
class-map type http loadbalance match-all DOMAIN-AND-PATH-CM
  2 match http header Host header-value "www[.]domain[.]com"
  3 match http url /very-long-path/.*
