Warning message
supplementary-service qsig call-forward in which way?
Dec 12th, 2011
hello i have a forward problem on a qsig with alcatel which is known for a log time here (2004) i found no sultions for the moment
i found that command that may help
but i can't understand in which way it works
i hope it is like this
if a receive a message call forward froma pabx (if the phone i call is forwarded to another one)
the gateway will be able to redial the new number recieved on the forward message.
if it's not like thath please tell me
regards
Alain
acampbell Mon, 12/12/2011 - 09:14
  • Green, 3000 points or more
Not sure what systems you are using
Here is some info from CME to Alcatel 4000- probaly the interfacing will be very similar to your set up
Call Forwards
The Alcatel PBX will not perform call forward by join. It always performs a reroute in calls where a PBX phone is in the middle.
For calls from Cisco Unified Communications Manager Express 4.0(2) to a PBX phone that is then forwarded locally to another PBX
phone (e.g., Phone C1 calls Phone A, and Phone A forwards to Phone B), the Alcatel PBX sends a reroute proposal, and the Cisco
Unified Communications Manager Express responds with a second SETUP message (i.e., a new call). This feature is inherent to the
PBX and can not be turned off.
For local CFNR from a SIP phone to a PBX phone to another PBX phone (e.g., phone C2 calls phone A, and phone A forwards on no
response to phone B), the call connects, but has 1-way voice.
For ”trombone” or ”hairpin” calls from a PBX phone to a Cisco Unified Communications Manager Express SIP phone to a PBX phone
(e.g., phone A calls phone C2, which forwards to phone B), the call completes, but Cisco Unified Communications Manager Express
does not perform a reroute, even when reroute is enabled.
For ”trombone” or ”hairpin” calls involving overlap dialing from a PBX phone to a Cisco Unified Communications Manager Express
(SCCP or SIP) phone to a PBX phone (e.g., phone A calls phone C1/C2 using overlap dialing, and C1/C2 forwards to phone B), the call
completes, but there is no reroute. If the Cisco Unified Communications Manager Express phone is a SIP phone, there is no reroute
proposal. If the Cisco Unified Communications Manager Express phone is a SCCP phone, there is a reroute propsal, but the PBX
ignores it. It is believed that this is because overlap dialing on the Alcatel PBX is accomplished by a direct trunk select (as opposed to
ARS), and this causes the PBX to ignore the reroute proposal because the first trunk is ”nailed up”. This is believed to be an inherent
limitation of the Alcatel PBX.
Forwarded calls originated from a PBX extension to a remote Cisco Unified Communications Manager Express SCCP extension, and
forwarded to a local Cisco Unified Communications Manager Express extension (e.g., A calls G1, and G1 forwards to C1), Cisco
Unified Communications Manager Express performs a QSIG reroute, even though a QSIG reroute is not in order (i.e., there is no QSIG
”hairpin” or ”trombone”).
For many call forwards, the forwarding called name and number are not displayed on the final destination.
For many call forwards, the called (connected) name and number are not updated on the original phone. In some instances, the correct
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/pbx/interop/notes/562133nt.pdf
Alex
alaincayron Mon, 12/12/2011 - 09:27
yeah i saw this message
but as i'm not using call manager and attacking directly in sip the 2811 i wonder what this command mean as it seems to me one solution
as in your pdf it is not said how this new call is 'automatically' done.
lucas sousa Mon, 02/24/2014 - 23:04
hi guys, can anyone direct me on how to connect or login the alcatel pbx system so i can make proper changes to sip with my CME as i already have all the documentation on how to make changes but dont know how to log in alcatel 4400. Thanks in advance.
