Temperature above threshold / Running in modulated clock mode
Dec 12th, 2011
When I'm accessing information on the MARS via. web interface, the console starts complaining about temperature.
Message from [email protected] at Mon Dec 12 13:19:37 2011 ...
corpmars01 kernel: CPU0: Temperature above threshold
corpmars01 kernel: CPU0: Running in modulated clock mode
Message from [email protected] at Mon Dec 12 13:19:42 2011 ...
[pnadmin]$ show healthinfo
Fan ID      RPM            Status
CPU Fan 1   6750 RPM       OK
Monitored Item           Temperature(C/F)     Status
CPU Temperature          55/131              OK
System Temperature       26/78               OK
I've checked and all fans (power supply, case fans, CPU fan) seem to be blowing air properly. The MARS sits in our AC-cooled data center and System Temperature usually runs around 24-26 degrees. I've seen the CPU run anywhere from 45-72 degrees, however it's normally between 48-53 degrees.
Is this normal/ to be expected?
Greg
