Warning message
Lwapps join process
Dec 13th, 2011
I have a problem where I have 2 controllers.  Primary controller is completely full, but the Lwapps will try to join it first and for some reason kicks previously joined waps off so that it can join.  The previously joined WAPs will then join the secondary controller.  Is this normal operation?  Is there a way I can make the WAPs join the secondary controller automatically?
Any help would be greatful.
Larnel
Scott Fella Tue, 12/13/2011 - 09:28
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
First make sure master controller mode is not turned on in either wlc and you have mobility configured between the two wlc. Then you will need to enable ap fallback on rack wlc and then in each ap, you will define what is the primary and secondary wlc for that AP.
Sent from my iPhone
larnelhight Tue, 12/13/2011 - 09:36
Ok, all of that is already set, but should AP Faillback be enabled on both WLC's??
Scott Fella Tue, 12/13/2011 - 09:38
  • Hall of Fame,
    2017 Wireless
Yes it should... This allows an ap on a secondary wlc fallback to the assigned primary wlc.
Sent from my iPhone
Leo Laohoo Tue, 12/13/2011 - 12:51
  • Hall of Fame,
    2017 LAN, Wireless
If your primary WLC is already full, I'd reconsider enabling AP Fallback.  There's no reason.
Scott Fella Tue, 12/13/2011 - 13:34
  • Hall of Fame,
    2017 Wireless
Guess I was assuming that the AP's would be equally placed on each wlc. That would be the best way.
George Stefanick Wed, 12/14/2011 - 21:57
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, October 2015
Ive had issues when my controllers are almost full and AP fall back in enable. Once a ap drops for whatever reason other APs are quick to hop on ... Then I would see them bounce back and forth from time to time.
just my 2 cents ..
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
