Unity Connections 8.6.2a Single Inbox Problem
Answered Question
Dec 13th, 2011
We have a Unity Connections Server version 8.6.2a talking to Exchange 2010 SP1.  We have verified Authenications, HTTPS, Certs etc.  If we run a test from the Edit Unified Messaging Screen, we get the following:
Severity                               Issue                               Recommendation                               Details
The validation results for unified messaging service Exchange are the following:        Service "Exchange": AuthenticationMode=[Basic] [use  HTTPS/validate] Server=[server.internaldomain.com] Type=[Exchange  2007/2010] Username=[domain\UnityUser]
The server domain name can be resolved.
Server server.domain.com can be contacted by pinging.
The service port for calendaring is functioning.
The certificate verification results from SSL is X509_V_OK.
This test does not test all aspects of the configuration of  the service. To complete testing, add a unified messaging account for a  user and test the account using the Test button on the Edit Unified  Messaging Account page.
However under the user we get:
The validation results for the user unified messaging service  account [email protected] with service Exchange are the  following:        Service "Exchange": AuthenticationMode=Basic [use  HTTPS/validate] Server=[server.internaldomain.com] Type=[Exchange  2007/2010] Username=[domain\UnityUser]
Failed accessing [email protected] on server.internaldomain.com                                    .        Diagnostic=[] Verb=[] url=[] request=[] response=[]
The system failed to perform a typical calendar operation.                                    Refer to other warnings and errors generated by the tool, and check the Tomcat log file for details.        The system failed while trying to make an API call.
I'm completely at a loss.
Jason,
My bet is that when you are able to view the Tomcat logs from Unity Connection you will find that you are getting an error 401 response from Exchange.
We ran into the exact same issue with our Unity Connection 8.6.2a system connecting with our Exchange 2010 SP1 server. After working with TAC and Microsoft we were able to get this working by recreating the EWS virtual directory in IIS on the the Exchange 2010 CAS server.
I hope that helps.
Michael Putney
Overall Rating: 5 (1 ratings)
jasonmyersccs Tue, 12/13/2011 - 13:22
I've never seen the diagnostic= verb= url- request= reponse= be empty before.
Bradford Magnani Tue, 12/13/2011 - 13:27
  • Cisco Employee,
Hi Jason,
You're hitting a new defect that's being investigated:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtw78566
You'll want to collect the Tomcat and Mailbox sync traces to see what the actual failure is.  The diags should have the errors that would normally be presented in the GUI.
Hope that helps,
Brad
jasonmyerscbts Tue, 12/13/2011 - 14:34
I would do that except for the fact that the RTMT with 8.6.2 gives me a java error everytime I try to use it.  Is there a way to get a different version?
Bradford Magnani Tue, 12/13/2011 - 14:36
  • Cisco Employee,
You can download RTMT from the Plugins menu item within Connection Administration and install that version.
jasonmyerscbts Tue, 12/13/2011 - 14:48
I get the following when I attempt to run that after install:
C:\Program Files\Cisco\Unified Serviceability\JRtmt>".\jre\bin\java" -Dsun.java2
d.d3d=false -Xbootclasspath/a:.;.\lib\xerces.jar;.\lib\log4j.jar;.\lib\jcchart45
0J.jar;.\lib\collections.jar;.\lib\JbcBeans.jar;.\lib\activation.jar;.\lib\axis.
jar;.\lib\axis-ant.jar;.\lib\commons-discovery.jar;.\lib\commons-io-1.3.2.jar;.\
lib\commons-logging.jar;.\lib\commons-lang-2.1.jar;.\lib\commons-net.jar;.\lib\i
fxjdbc.jar;.\lib\mail.jar;.\lib\maverick-debug-all.jar;.\lib\jaxrpc.jar;.\lib\sa
aj.jar;.\tzupdater.jar;.\lib\jide-common.jar;.\lib\jide-dialogs.jar;.\lib\jide-g
rids.jar;.\lib\wsdl4j.jar;.\lib\javacsv.jar;.\lib\jtds.jar;.\lib\commons-beanuti
ls.jar;.\lib\commons-collections.jar;.\lib\commons-digester.jar;.\lib\commons-el
.jar;.\lib\commons-jexl.jar;.\lib\commons-scxml.jar;.\lib\derby.jar;.\lib\xalan.
jar;.\lib\openssoclientsdk.jar -jar JRtmt.jar
Exception in thread "main" java.lang.NullPointerException
        at com.cisco.ccm.serviceability.rtmt.ui.SystemUtil.getLog4jConf(Unknown
Source)
        at com.cisco.ccm.serviceability.rtmt.ui.JRtmtMain.initTrace(Unknown Sour
ce)
        at com.cisco.ccm.serviceability.rtmt.ui.JRtmtMain.main(Unknown Source)
Bradford Magnani Tue, 12/13/2011 - 17:24
  • Cisco Employee,
Yeah... looks like some sort of Java conflict with your machine.  I'd suggest trying on another machine.  The other option is to push the diags off to an SFTP server from UC's CLI.
file list activelog cuc/diag_*
file get activelog cuc/filesyouwanttocollecthere
Brad
Correct Answer
Jason,
I hope that helps.
Michael Putney
jasonmyersccs Wed, 12/14/2011 - 13:12
You sir are 100% correct.  After grabbing the logs, we had this exact issue!
Thank you so much!
Jason
