Cat 6500 - To erase configs on Switch and the MSFC
Hello and greetings.
I have an older Cat 6500 switch with an MSFC. I am required to erase all configs on the switch. I would like to know if there's any sequence of actions I need to follow. For, I have run the command 'clear config all' on the switch. Now, I am not able to access and erase the configs on the MSFC. I have to clear the configs on MSFC. So, given the scenario, how can I best erase the configs on the MSFC? I attempted 'session 15' and other session commands -but not able to erase. (err msg: module not found)
Any help . suggestions / links will be much apreciated!
thanks,
kishan
glen.grant Tue, 12/13/2011 - 15:17
  • Purple, 4500 points or more
  From the supervisor (L2)  type in "switch console"  and that should take you into the msfc . Do a write erase then reload .
