view port-security disabled port
Dec 14th, 2011
Hi, I have a lots of cisco catalyst switches, and I need to find out wich switch has port with port-security feature disabled.
I have a comand show port-security, but it shows me just enabled  port-security feature on ports, but I need opposite info, may be someone know how to view port table without port security
thanks
Overall Rating: 4 (2 ratings)
Krasnoperov Wed, 12/14/2011 - 01:12
thanks but, I think you dont understand my question, your comand just shows err-disabled port, but with ports everything OK, they are int working state, no violation happends for now. let me explain on example, I have two ports in my config
interface FastEthernet0/2
switchport mode access
switchport block multicast
switchport block unicast
switchport port-security
switchport port-security violation restrict
switchport port-security mac-address sticky
storm-control broadcast level 5.00 4.00
storm-control multicast level 5.00 4.00
storm-control action trap
interface FastEthernet0/3
switchport port-security maximum 2
on interface 0/2 I have a command
it means my port is secure
on interface 0/3 I dont have this command
it means it's unsecure
so I need to some show...bla-bla-bla writen in one line to see ONLY unsecure interfaces
hobbe Thu, 03/15/2012 - 06:01
Is this good enough ?
sh ru | i (interface|port-security)
or
sh ru | i (interface|violation)
This will still give you all ports but it will also tell you wich are configured and wich is not configured.
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
as you can see here Gig1/0/8 is configured the others are not since they have no row of switchport port-security beneath them.
This sh ru will pick out any line with "interface" and any line with "port-security" (or "violation)
Good luck
Krasnoperov Thu, 03/15/2012 - 06:21
thanks, but this comands just show interface number and lines with %port-security%, in your example it doesn't mean that
interface configured for port security, because only intrface with \switchport port-security\ and nothing after that is secured, for example:
(non secured)
sh run int g1/0/8
(secured)
sh run int g1/0/8
How can just interface with this?
hobbe Thu, 03/15/2012 - 06:27
If you use the word port-security instead of violation then it will show you just that.
It will still give you all the rest but it will give you the line with port-security only.
so you will be able to tell if it is connected or not.
michaelillgen Thu, 03/15/2012 - 06:30
@hobbe:
Thank you very much. You point me to the right direction.
@Krasnoperov
Can you try this command?
sh ru | i (interface|port-security$)
Krasnoperov Wed, 12/14/2011 - 01:15
nope it's just shows ALL (not just inteface section) line in my config WITHOUT port-security lines, and I see all interfaces with&without portsecurity
Beetlejuice01 Wed, 12/14/2011 - 02:14
So you want to see wich port are not configured with port-security command...I don't think it's possible... it is faster to do a show run and use find function. But maybe i'm wrong... i've thinked same solution who Cadet had suggested but if not work i've no idea...
cadet alain Wed, 12/14/2011 - 03:03
I've got no switch here to verify but you could try sh run interface | exc port-security
Regards.
Alain.
JohnTylerPearce Wed, 12/14/2011 - 05:54
I just tested that cadet, if you do that, it will show all ther interfaces but just excluding the port-security configuration statements. I was not able to get a single command to do this, but you can modify the following one.
show port-security interface gi0/1 | i Port Security|Disabled
This will show you if the port has port security enabled or disabled.
You can just modify each statement if you want. Personally I would
just do a show run, but each his own.
Hope that helped.
Krasnoperov Sun, 12/18/2011 - 23:48
thanks but it's only for 1 port, and I need to view all ports, so I need to do this command for each
Krasnoperov Sun, 12/18/2011 - 23:49
sh run interface
% Incomplete command.
so I need to define just one interface in this command,
michaelillgen Thu, 03/15/2012 - 03:43
@Krasnoperov:
Have you found a solution for your problem? I would like to see all the ports which have no 802.1x authentication enabled too. But unfortunately I have no idea how to do this.
Krasnoperov Thu, 03/15/2012 - 04:53
Nope, unfortunatly. But as far as I know, this shuld be done with TCL, but I not coder person...
