uni port vs access port ---- nni port vs trunk
Dears,
Kindly advise difference between
1- uni port vs access port ?
2- nni port vs trunk port ?
Many Thanks
BR,
Sherif Ismail
8 Replies 8
yashfaqu
Users from UNI to UNI cannot talk, its like Access with protected
UNI port will not run STP as well as CDP and LCP.
NNI and Trunk ports are almost similar.
Thanks Yasir for your assistance
Another question plz
So when to use NNI and when to use trunk ?
Many Thanks
Sherif Ismail
Hi Sherif,
Well, i think u took it in different way, NNI and UNI are Network Port Types, for Isolating purpose, and Access and Trunks are operational attributes.
UNI Cannot Talk with UNI Port --Either its Access or Trunk.
NNI can Talk with NNI and UNI port --> its similar like Private VLANS.
NNI port will always be your Trunk or uplink port, it can also be your access port as well.
In UNI port you will connect your customers, and most probably it will be Access port.
In NNI port you will connect your uplink, and most probably it will be your Trunk port or could be your access port.
As per official Doc:
Q. What is UNI/NNI?
A. UNI/NNI is the classification of port types designed for the Metro  Ethernet market. UNI, User Network Interface, is the interface that  faces the subscriber, and NNI, Network Node Interface, is the interface  that faces the service provider network. By labeling each port as UNI or  NNI, the software can optimize each port for its role.
Dear Yasir,
Many many thanks for your support today
Hi Sherif,
The choice of access vs. trunk port (on UNI's) is also dependent on the customers requirements and the type of ME service (EPL or EVPL) the customer will need.
This can also be tricky. Generally, if the customers CE's are routers, you can provide either an Access Port if the routers interface is a "routed port". Or if the customers CE has a trunk port (sub-interfaced), then you would need to provision a Trunk Port. Because both of these scenarios are "customer-facing" ports, and as above-mentioned by our colleague, they will almost always be UNI ports, not NNI ports. Customer-facing NNI's are generally used in managed-CE scenarios.
Cheers.
Thanks Hashiem
Just curious, are there any examples of a CE configuration where it connects to an NNI port but wants to sent trunks over that NNI port (ie, there are multiple destinations, say 600,601,602) but wants to send trunk information over the link and knows which place to place the trunks being sourced from the various UNIs (coming over the tagged packets)
Marcos
Great write-up! Saved me a lot of time!
