12-14-2011 10:12 PM - edited 03-16-2019 08:32 AM
HI,
I try to configure cisco 9971 for cisco unified mobility but i come to know that cisco 9971 didnt support softkey templete.
Is there any procedure to configure cisco unified mobility on cisco 9971
Solved! Go to Solution.
12-16-2011 07:41 AM
Hi Asim,
Just to add a note to the great info from Bill, Java & Jonathan (+5 each )
You need to use a programmable feature buttons for Mobility;
Table 7-4 provides information about some of the features that are available on softkeys, some that are available on dedicated feature buttons, and some that you need to configure as programmable feature buttons. An "X" in the table indicates that the feature is supported for the corresponding button type or softkey. Of the two button types and softkeys, only programmable feature buttons require configuration in Cisco Unified IP Phone administration.
Note The Cisco Unified IP Phone 8961, 9951, and 9971 does not use softkey templates in Cisco Unified Communications Manager administration.
For information on configuring programmable feature buttons, see the "Modifying Phone Button Templates" section.
Phone button templates let you assign speed dials and call-handling features to programmable buttons. Call-handling features that can be assigned to buttons include Answer, Mobility, and All Calls.
Ideally, you modify templates before registering phones on the network. In this way, you can access customized phone button template options from Cisco Unified Communications Manager during registration.
To modify a phone button template, choose Device > Device Settings > Phone Button Template in Cisco Unified Communications Manager Administration. To assign a phone button template to a phone, use the Phone Button Template field in the Cisco Unified Communications Manager Administration Phone Configuration page. Refer to Cisco Unified Communications Manager Administration Guide and Cisco Unified Communications Manager System Guide for more information.
•The default Cisco Unified IP Phone 9971 template that ships with the phone uses buttons 1 and 2 for lines.
Cheers!
Rob
Please remember to tag your threads and help support "Teachers without Borders"
https://supportforums.cisco.com/community/netpro/idea-center/communityhelpingcommunity
12-14-2011 11:54 PM
You manage features on the 9971 using the Feature Control policy. Go to Device>Device Settings>Feature Control Policy. Create a new policy and check the appropriate boxes. Then associate the policy to the device.
HTH.
Bill
please rate helpful posts
12-15-2011 02:51 AM
hi,
I cant see any softkey option in feature control policy and i am not able to created any softkey when the phone is on hook.
Normally in cisco 7900 series when creating the softkey the mobility is there by default we jsut need to shift it to right side and then save
any idea ?
12-15-2011 09:08 AM
9900/8900 series really do not use a softkey template, you cannot think of them just as another 7900 series and do the same config. As Bill mentioned, to enable or disable which softkeys are shown on the device you need to do so thru the Feature Control Policy.
This is all contained in the administration guide which should always be the 1st place to look on how to configure a device.
You can limit the appearance of some telephony features on the Cisco Unified IP Phone 8961, 9951, and 9971 by enabling or disabling these features in the feature control policy configuration. When you disable a feature in the feature control policy configuration for a phone, you restrict the user's access to the feature and the softkeys associated with the feature does not display on the phone.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
12-16-2011 04:55 AM
Just to answer the Mobility piece of this: The 8900/9900 phones do not have a Mobility softkey. You need to assign this to a line button. There are something like 16 features that are softkeys on the 7900 but must be physical buttons on the 8900/9900 phones. I'm trying very hard not to turn this reply into a rant so I'll stop typing now.
12-16-2011 07:41 AM
Hi Asim,
Cheers!
Rob
12-17-2011 11:11 PM
thanks guys for your replies.I got it working
You have to copy original phone button templele of cisco 9971.Go to third line and click the box to see serveral softkey already there in the system.Select mobility there and call this new phone button templete in the cisco 9971.thats it.
12-20-2011 02:42 AM
Rob
Thanks for sharing this information. Informative !
Lavanya
