Scott Fella Wed, 12/14/2011 - 22:35
You would need a radius server and then you can do 802.1x using machine authentication.
mml4cisco Wed, 12/14/2011 - 22:43
Thanks. Any steps by steps configuration guide I can follow?
Scott Fella Wed, 12/14/2011 - 22:45
What radius server would you use? IAS, NPS, Cisco ACS. I will try to find a link.
Sent from my iPhone
mml4cisco Wed, 12/21/2011 - 12:02
The 802.1x always uses the Windows users to authenticate instead of the machine ID for authentication. How can I force the WLC to use machine authentication?
Scott Fella Wed, 12/21/2011 - 12:16
it's not the wlc.. It's the windows client and radius. Windows XP requires a registry hack and Widows vista and 7 has the option in the wireless profile.
